Howdy. I am due for a rebuild, what is the best option I have? I've seen a few options, like cubs and also seen sleeve/piston repair "kits" but what's the best bang for my buck? Keep in mind I would like to do it all in my garage. I already rebuilt the carbs ($28 incl. shipping eBay) and replaced all my wheel/swingarm bearings, all I need is a motor refresh... :)
What is your current bore size?
Mods?
Riding style?
Are you comfortable using a dremel on your cylinders?
Budget?
Mods?
Riding style?
Budget?
My bad, I forgot all that info!!!
Stock motor, stock airbox, FMF exhaust, TORS eliminated, UNI filter.
Mainly off-road (no drag, well ocassionally but with other non-drag shees.)
I am comfortable using a dremel, scary thought though...lol
More HP/better acceleration is definately something I would chip in a few extra bucks.
Budget = no more than $500
Oh, and I want to be able to use 93 octane all day long.
Edited by m4f1050
Mods?
Riding style?
Budget?
I know everyone on here says to go through a shop for porting, but I'd love to try myself. Seems you got alot of insight into this SLORYDER?! you mind sharing some info?!
to the OP: I just rebuilt mine for about $300. Bore/Hone, all new seals and some bearings, and of course some WSM slugs with a welded crank. I too was on a budget!
I'm assuming you need an overbore?....
Wiseco pistons, bore- $300ish
Shave stock head .025"- $50
Top end gaskets- $40ish
Boysen reeds-$40 ish
Dremel w/ bits-$100
Mod your timing plate to give you +4 advance
Port your reed cage to look like this. Make sure the pedals have 1mm of surface all around to seat on
Nexy open your intake to look similar to this. You will narrow the bridge by 2mm, and raise each side of the port 3mm, and lower it 1mm. When you do this make sure you don't leave any sharp edgaes on the inside of the cylinder where the piston rides; chamfer the port. Go over the chamfer with very fine sandpaper oiled with wd-40
Next, smooth out these sharp edges at the botom of the cylinder; the transfer port tunnel entrance
To look like these, even smoother if possible
Finally, you need to clean up your exhaust port. This is looking through the exhaust port of a non-banshee. See how the sleeve isn't even with the aluminum?
Grind the sleeve until everything's flush, like this
Sand all the carbon out of the exhaust port, then go over it with a fine sand roll until it's as smooth as you can get it
Follow the instructions on chamfering that I gave for the intake.
This is your basic clean up port job, and really hard to mess up.
These mods will REALLY bring your shee to life. And if you feel confident about your dremel skills, I can tell you hor to get another 10-15 hp out of the exhaust port.
Edited by SLORYDER
advance timing to plus 4 New timing plate $35
vforce 3 reeds- $219
true and weld crank-$100
and get the Vitos superstock piston kit-$210-225
I put in these kits on stock motors all the time. Im putting one in the wifes bike. The claim and have proven gains of 6-8hp with these pistons and minor mods. I sell alot of them, but you will also get people who for some reason hate them. Me personally I think there a great setup and have never had any problems with them or any Vitos parts.
If you can afford to have motor ported definantly go that route. A good port job is going to run you at least $400. By going with the superstock kit it allows you to afford some other mods you can and need to do before you do the port work. Its really all about the money you have to spend and the direction you want to build your bike. Hit me up anytime for parts or to discuss further options. Pm or give me a call anytime.
Yeah I was going to recommend the vitos pistons, but I figured the money would be better spent on a dremel and some weiscos...
true and welding the crank is definately a good idea IF you plan on splitting the cases. Then you should go ahead and buy new seals. How old is your banshee?
I'm in the middle of a rebuild and my budget went from 600 to 1500 bucks, speed costs money, I can't take it with me when I go upstairs to live! then I went and bought tires. the wife loves my banshee :lol:
Edited by toytech
Ok, so I have the following already:
VForce 3's
Ricky Stator (200w with timing and set +4 forgot to mention that)
So basically I would need new pistons (Vito suggested, Wiseco for price,) a port job and .025" less on stock head.
What's the minimum bore oversize I can go? .10?
If going aftermarket/cool head what cc domes should I be looking at?
Edited by m4f1050
VForce 3's
Your weakest link right now is your compression.
Also your porting.
Doing the clean up port will help you more than the vitos pistons, and you will have a dremel for when you want to unleash big hp.
Unless you are looking for bling, and plan on changing setups 3 or more times,lose the cool head idea IMO
What bore size are you at right now?
You know, I am about to find out when I open her up. I called the previous owner and he said that it had pistons, but IDK, it ran like any other shee with expansion/pipe. What is the stock measurement? (I have a measuring tool I can just take heads off and check.)
Edited by m4f1050
If you are going to continue running that Ricky Stator, I would recomend getting a spare stator to carry with you. Sooner than later it will fail and you will be stranded and/or lose out on a riding trip. Just search Ricky Stator on here and you should find all kinds of reasons to ditch it.
Edited by bansheesandrider
Dremel w/ bits-$100
I would love kow what to do on the exhaust port! I am actually rebuilding my engine right now.
