Silentsoul
Everything posted by Silentsoul
  1. Any pics of the carbs and intakes?
  2. How much for just the end cut tranny gears?
  3. I would like to have the carbs, but I don't want the filters. I know you said you would like to sell as a package. Pm me and let me know.
  4. I was wondering exactly how long to run the plug before you chop it? Not trying to hi-jack your thread, I'm fixin to be in the same boat as you are, so just tryin to get a little info.
  5. I am currently running 32:1 with maxima castrol. I am thinking about swapping to redline oil, just have not done it yet. I hear it burns cleaner than the maxima.
  6. Has anybody ever tried the e3 spark plugs in a shee? I was just wondering if running them might help with fouled plugs.
  7. thanks for the input! just out of curiosity, what % of stock cranks are out of time?
  8. Is it possible to weld your own crankshaft? Also is every factory crankshaft out of time, and needs to be trued?
  9. I'll take'em send me your paypal addy!
  10. I want the carbs. send me some pics if you don't mind. But unless they are in rough shape consider them sold! Payment through paypal ok?
  11. So the pwk's are worth the extra 125.00 bucks, for what reasons? I am new to the whole carburetor game.
  12. Has anyone ever run a set of OKO carbs? I was just wondering, because for 200 bucks you can get two 30mm d slides. Seems to good to be true.
  13. Thanks for your help! I will play with the mains and needles, otherwise I'll have to find some 27.5 pilots. I think I have a set of 30's Sorry meant to say 25's
  14. Also, would running an oxygenated fuel be a bad idea at that elevation?
  15. 30 pilot's, 320 mains for 70 degrees . Proly not much difference in the temperatures. I'm jetted for winter here where I live, and it's about the same temprature in the summers where I'm going.
  16. I live in texas right at 2400ft above sea leval, going to cloudcroft new mexico in 3 weeks which shows to be around 8500ft above. Running toomey t5's pods, shaved stock head, +4 timing, can't remeber jet sizes off the top of my head, any ideas on how many mains I should drop?
  17. It was a new hotrods crank everytime. Mods are in the first post, nothing to radical.
  18. Would you mind explaining a little bit more on the crank being out of phase? I have never heard of this, so this could have very well been the problem.
  19. I was running klotz at 32:1. This happened 3 times in a row. I went through both carbs, played with jetting, timing was at +4.
  20. Hey guys! Just a quick question on a 1994 banshee that I owned. It would run like a raped ape for about 10 hours, then it would seize the right rod to crank, and the right cylinder,piston, would be trash. I tore complety down, and did a leak down test when I rebuilt it, it passed, The top of the pistons both had the leathery brown look to them, so I know it was not running lean or rich. It was a stock stroke, bored .40, with a mild port job, and timing advance plate tors were not removed. Any ideas?
  21. Around the lubbock area
  22. I am looking to build a banshee for dirt/sand drags. But before I jump off into another project, I wanted to find out if there are any drag races in Texas.
  23. Like the topic says, I am needing to get my crank trued and welded. Is there anyone that you guys would suggest? Also, what are the best main bearings to run on a rebuild?
