ionroller Posted May 28, 2010 Report Posted May 28, 2010 I just bought a old banshee, and off ebay a pro flow intake, and fmf fatty pipes with the power core 2 slencers. after a little reasearch I found I should get 340 mains and 30 pilots. Is that correct? also where can I get the jets and how hard is it to repack power core 2 and what to use. Thanks Quote
streakx Posted May 28, 2010 Report Posted May 28, 2010 340 mains is too big for your mods (is there any other mods ?) ... if you keep the lid on the air box 280-290 would be a good start .. whats your elevation and temp ? Chris Quote
ionroller Posted May 28, 2010 Author Report Posted May 28, 2010 Stock besides the pro flow and fatty Elevation 600 feet Temp. 0-90 degrees What should I run in winter and summer Quote
banshee#44 Posted May 28, 2010 Report Posted May 28, 2010 go with 280 mains and 25 pilots if your not running an airbox lid try 27.5 pilots and also keep your needle on the 3rd clip Quote
ionroller Posted May 28, 2010 Author Report Posted May 28, 2010 how much do jets cost, I cant seem to find them online. Is it best to go to a dealer? Quote
GrMeyer Posted May 28, 2010 Report Posted May 28, 2010 My local shops never have the jets I needed. And then if they had the jets. They would only have 1 of the jet i needed. So I just ended up ordering from like 250-350 mains jets. Just contact a site vendor and go from there!!! As Banshee#44 said for starting points. Sounds good to me. And repacking is easy. Just make sure you dont pack them to tight. The hardest part is getting all the old shit out. Quote
