bansheemann420 Posted May 12, 2010 Report Posted May 12, 2010 (edited) i have a 02 banshee kn airfilter 12 holes in lid, boysen superstock reeds and stock bore. what size main and pilot jets would i use at 100' sealevel? 60-80 degrees Edited May 12, 2010 by bansheemann420 Quote
locogato11283 Posted May 12, 2010 Report Posted May 12, 2010 i start with 230 mains and 25 pilot. needle with the clip in the middle. air screw .5 to 2 turns out depending on where the throttle response seems best. Quote
bansheemann420 Posted May 13, 2010 Author Report Posted May 13, 2010 i start with 230 mains and 25 pilot. needle with the clip in the middle. air screw .5 to 2 turns out depending on where the throttle response seems best. someone told me i shouldmove the clip one spot leaner on the needle due to the reeds ?????? Quote
jupiterbanshee Posted May 20, 2010 Report Posted May 20, 2010 i have a 02 banshee kn airfilter 12 holes in lid, boysen superstock reeds and stock bore. what size main and pilot jets would i use at 100' sealevel? 60-80 degrees fuel makes power, so dump as much fuel as u can into it, if it bogs then back off one size Quote
