oh maaaan i did a leakdown test and i just found a 1/8 '' perfct round hole in the base of my juggs hiding behind where the rear radiater hose that goes to the head , right where it bolts to the cases?? it was covered by a chunck of silacone . im going to visit the guy that did my rebuild tommorow i think this guy screwed me . no way he missed it when he did the work , this dude works on bikes for a living been races banshee for 20 years............. anyway is there any posible way to fix ? thanks
I would weld it up
that ll be great i just started welding clases , should i keep it bolted on so it wont destort , i hope i can get to the back of the hole to put some kind of backer plate ? anyone done welding like this ....... lil help i just starting weldind looking fo the best way to get fixed up thanks again
k i poped off the cylider off and it looks like who ever did the port job got a lil to close doing the booste ports and went through the side, also theres 3565 scribed in the bottem side are these #'s anything or jus id marks?? looking for some one that has fixed by welding or whatever this kinda prob or if it fixable thanks again again
a lil tack weld will fix it right up. i have cracked the bases by the bolt holes and welded them up and they were fine. get u r instructor to throw a lil tack on there.
heres a couple pics
pic looking in from the bottem.............. u dont think heat will be a factor where the metel is so thin there? thainking maybe cold welld but dont want to worry it gunna xcome loose when riding ...also what are the cylinder made of ?? THANKS AGAIN for the help guys
As good as these guys advice is remember that every setup is different and different problems happen to every bike. Consider what it would cost to buy new jugs now, and how much it would cost to buy new jugs on top of any other damages you may do IF it does come loose or melts. Not saying you shouldn't do it it could be an easy fix, but keep that in mind.
well my teach welded it from both sides then i took my dremel and evened everything out , inside looks great the out side got a big booger or aluminum weld im gunna go over it with some silocone and do a leakdown and see what happens , it ran for 2 years with jus the silicone before i found it so hopfully the weld and silicone togather will hold tight ,prob not the best fix but if it does burn up ill guess that will be an excuse to tell the girl that i got to rebuild and go to 4 mill :D thanks
:angry: im not sure but i think some guys fillin that whole area with weld then smooth it out. but if you dont want to get that crazy a tack weld will do the trick.maybe bring it to the builder and be like wtf :angry:
ya got the hole tacked then filled the lil channel 1/4 way with cold weld.i did a leak down held no prob hope it hold under load and vibration also went to choke the builder i mean talk to him but "he don t no" i really got a feeling this guy switched juggs with some he tryed to port but i never looked what i had b4 i droped it off to him for 2 months for a top end ?? anyway ill be doing my work from now anyone else mark u poop or make sure u know what u got b4 u drop it off to a stranger thanks
