SD1026 Posted April 6, 2010 Report Share Posted April 6, 2010 just purchased direct drive clutch cover any reveiws Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 6, 2010 Report Share Posted April 6, 2010 Is it the a New Die Cast cover or is it a machined stock cover with an extended ring welded / expoxied on? I like mine. Just had to bend the rear brake lever a little. I am sure your's is a 12 bolt lexan. That is way better than the older 6 bolt. Don't use lock tight on the lexan bolts. The locktigh will cause the lexan to crack really bad. Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted April 8, 2010 Report Share Posted April 8, 2010 Im pretty sure he got the new die cast cover. Supposed to be all beefed up, alot stronger than the stocker. Re enforced all the way around And also it the 12 bolt design, not the 6 What is everyones thoughts on these?? SD is the test dummy on these, if they work well and look great Ill be ordering myself one aswell. Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted April 8, 2010 Report Share Posted April 8, 2010 I'm pretty sure the 12 bolt design is the one that Jeff sells. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted April 8, 2010 Report Share Posted April 8, 2010 They're nothing new.. Been around awhile now. They are better then a modded stock cover which in time can leak. I'll be getting one from them for the new build pretty quick.. As always.. a great product from Direct Drive.. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 8, 2010 Report Share Posted April 8, 2010 I have been running the direct drive New Die cast cover for 2 years now. No leaks. I did have to use a dremal to clean up around the water pump. I just cleaned up the casting so I wouldnt tear up my billit aluminum impeller. I could feel just a slight rub. I just left it that way the cover and impeller would wear in and make a real tight clearances. I havent had any leaking issues. I just PC'ed mine black. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted April 8, 2010 Report Share Posted April 8, 2010 funny, i was just getting on to post pics of mine........and the water pump thing, you have to push out on it from the inside, and that's the clearance it will be at when it is running, since the coolant being sucked in and forced inward will apply outward pressure, otherwise, no pump being made will last long at all.......anyways, here's mine- i'm gonna try and put it on in the next few days, if it stops snowing, lol Quote Link to comment Share on other sites More sharing options...
SD1026 Posted April 8, 2010 Author Report Share Posted April 8, 2010 That cover looks sweet. I was thinking of powder coating my clutch hub also. What's the deal with the impeller??????? It will feel like clearance is a issue but the once pressure is applied by cOolant its all good???? Not too worried they do have a lifetime warrenty. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 8, 2010 Report Share Posted April 8, 2010 My clearance issue was on the side of the impeller. Where the step scrapes the fluid off the out side of the impeller. Quote Link to comment Share on other sites More sharing options...
SD1026 Posted April 15, 2010 Author Report Share Posted April 15, 2010 funny, i was just getting on to post pics of mine........and the water pump thing, you have to push out on it from the inside, and that's the clearance it will be at when it is running, since the coolant being sucked in and forced inward will apply outward pressure, otherwise, no pump being made will last long at all.......anyways, here's mine- i'm gonna try and put it on in the next few days, if it stops snowing, lol Was there any issues with powder coating that inner clutch plate? Did it hold up to the oil,flex,and what ever other abuse it gets??? Quote Link to comment Share on other sites More sharing options...
rgdrum Posted May 10, 2010 Report Share Posted May 10, 2010 just purchased direct drive clutch cover any reveiws My brother has the polished cover with the 12 bolt lexan and the lockup, he bought the cover and a billet water pump cover from Cascade. He loves it and I am planning on getting one too. the only thing is that it sticks out kind of far and rubs on your ankle, I ride in skate shoes frequently so I could see it getting bothersome. Cascade is also GREAT, I havent heard many people talk about them on here, their out of Oregon they are the nicest most knowledgable people that sell you what YOU need and they have every part for a banshee. Quote Link to comment Share on other sites More sharing options...
SandShots Posted January 7, 2011 Report Share Posted January 7, 2011 great piece , theres no fitting issues at all' http://sandshots.smugmug.com/Motorcycles/ATV-Products/IMG0150/1015435571_hBTAW-M.jpg Quote Link to comment Share on other sites More sharing options...
