Hooptiee Posted April 5, 2010 Report Posted April 5, 2010 My Brothers Banshee - Stock bore , T5's,boyseen reeds,2 into 1 air foam filter, TORS elim kit. 827 ft above sea. 280 mains, 27.5 pilot's, clip down 1 on needle. It has a slight bog mainly 0-1/8th throttle and it just don't feel like it's pulling hard through the gears. he put a new set of BR8's in and ran it for about 10 minutes pulled them out and the left side "choke side" is a nice brown color looks good but the right side still looks new no color, put another set of plugs in and same result. It has decent compression and he said he was pretty sure it was firing on both cylinders,starts 1st or 2nd kick and idles smooth? Just thought I would get some feedback before I tackle it in the morning. Ty for any help Quote
01strokedshee Posted April 5, 2010 Report Posted April 5, 2010 if the plug didnt have gas on it the clean one that is i would pull that carb and make sure all the jets where clean and float was set right Quote
RadarRacing Posted April 5, 2010 Report Posted April 5, 2010 Thats my guess too no fuel on that side. Check from gas tank to carb and then carb as well. Quote
bansheesandrider Posted April 5, 2010 Report Posted April 5, 2010 Definitely sounds like a fuel problem. If you have a plugged pilot or main jet, it will idle just fine on 2 cylinders, but when you rev it up, the side with thr plugged jet will quit running. Clean your carb, keeping the float bowls on the correct carb, they are different from left side to right side, make sure the choke tube is installed between the carbs and properly sync your carbs. Quote
Hooptiee Posted April 5, 2010 Author Report Posted April 5, 2010 Took the carbs apart and the float bowls were on the wrong sides, switched around fired it back up and had a slight backfire on the right cylinder. noticed a oil leak coming out of the the clutch cover side, after removing the clutch cover found the primary drive gear nut was off and made a nice mess of the clutch cover, alum shavings everywhere. well if it ain't one thing it's another, have to work on the backfire after I get it put back together Quote
Cali Posted April 5, 2010 Report Posted April 5, 2010 Took the carbs apart and the float bowls were on the wrong sides, switched around fired it back up and had a slight backfire on the right cylinder. noticed a oil leak coming out of the the clutch cover side, after removing the clutch cover found the primary drive gear nut was off and made a nice mess of the clutch cover, alum shavings everywhere. well if it ain't one thing it's another, have to work on the backfire after I get it put back together How do you tell which float bowls go on which side? Quote
bebetekbanshee358 Posted April 6, 2010 Report Posted April 6, 2010 one of the float bowls have a choke jet in it the other doesnt.. look closely. Quote
Hooptiee Posted April 6, 2010 Author Report Posted April 6, 2010 How do you tell which float bowls go on which side? http://bansheehq.com/forums/index.php?showtopic=128425&view=&hl=float bowls&fromsearch=1 this link has some great pics of the float bowls Quote
