well i've decided to sell off alot of my extra banshee stuff, and a few machines, to free up some $ for other projects and free up some space because i'm losing some of my storage space at my parents place. i guess my dad wants his woodworking shop functional again.. so anyway... i'll add to this as a get more pics.. and such... if you dont; see somethign on here that you need then by all means ask me.. i've got A TON of banshee stuff and i'm more than willing to sell most of it.
all the parts are located in kouts, IN and if you want to come pick them up thats totally cool..
burgard +2+1 arms with spindles, tie rods and ends, complte ready to bolt on and go riding.. powercoated mirros black 2 seasons ago.. not much use on these.. i took them off because i acquired the same arms but chrome $350
lonestar std. length swingarm and lonestar carrier powercoated mirros black 2 season ago not much use on this either. normal adjuster hole wear on the carrier adjuster.. doesn't effect performance at all. the holes just elongate a bit.. this thing is like $800 new for the swingarm and carrier.. $425
lonestar antivibe stem works great... i rode with it 1 season on my trail banshee.. and then decided to go 250R for a trail machine.. has fat bar clamps on it .. $200
IMS 5.5 gal tank white comes with the fenders cut to work with it.. also white.. petcock is installed on it still as well i bought it and never used it.. $120
FMF Gnarley pipes chrome with powercore 2 silencers $275
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
burgard +2+1 arms powdercoated silervein.. powdercoat is comming off the bottoms a bit.. which is very normal fomr weeds and such rubbing the bottom front of the a arms.. and ohlins piggy back progressive shocks.. not sure on valving but they worked great for me.. i'm 210lbs and i used them with these +2 arms.. i pulled one shock cover off to show that the springs are yellow $700
banshee seat with custom 3 color flame cover.. would look great with the tank i'm selling.. in fact thats the tank in the picture.. foam is in good shape not lumps or holes that i've ever felt through the cover.. $80
stock steering stems.. got a bunch of em.. $30 shipped each..
exotx billet grab bar mad ewith a threaded hold flag in it.. i;ve never used it but i came off joe20002's bike so you know it's in good shape.. $40
banshee transmissions... i've got a few.. thats EVERYTHING.. both gear packs, drum, forks, pins, screwss, plates, ETC.. $125 each
unported bashee jugs.. i have 2 sets like this.. i'll double check the bore size.. i wanna say they are .020 over and .040 over... i can port these for your setup for an extra charge as well if your interested in having them ported PM me.. or text me.
$150 unported $400 ported.. (thats $50 off my normal port pricing)
kenda klaws 20x10x10 on ITP c series wheels.. lots of life left $100
swingarm shop +4 arm painted grey striaght and ready to bolt on and go $120
stock swingarm powdercoated silvervein straight and ready to bolt on and go $50
white maier plastic cut front and rear $80
stock shee footboards with the plastic guards.. guards have been repaired
in the mounting area but still work $30
other stuff i;ve got laying around no pic yet
complete running stock bore stock port banshee engine.. stock right down to the gaskets.. i tore the top end off and replaced the rings on teh factory pistons and rebuilt it with yamaha rings, gaskets, etc.. everythign is FACTORY on this engine and it runs great.. bolt this in your roller and have season of worry free ride time $1100
cases cases cases 4 sets of cases with no chain break damage,, 1 set with chain break damage..
01 frame with title.. straight and ready to build a quad on.. it's a michigan title.. i never transfered it to a indianan title. $225
t5 pipes and silencers pipes are painted black.. silencers are still the raw alum liek toomey sells em.
hush kit not spark arrested weld in a sparky and be silver lake compliant for CHEAP!! in fact i'll even give ya a sparky with a messed up mounting surface to weld into it.. $50
97 shee frame.. sub frame is tweaked... wheelie gone bad.. i have a replacement subframe for it that comes with it.. $150
stock cranks... i have a few of em... in good ready to run shape $120 each
stroekr cranks 2 in good workign order one has TZ side bearing.. also have 1 that needs a rod.. contact me for pricing
98 banshee roller.. powdercoat done 2 years ago and has never left the yard.. mounted an engine in it and made 2 passes in my pasture.. then ended up pullign the engine back ouit.. candy blue frame with silver arms and swinger.. +6 GRR swingarms stock a arms rear shock is a stock body gone through by GT thunder. set up for 190-210lb rider with THIS swingarm, white palstic with blue hood and tank cover all in good shape as well.. black seat in great shape too, renthal bars, chrome stock axle, lonestar rear hubs, bolt in youir engien and elctronics and pieps. toss on some wheels and you've got a NICE shee to beat up on.. $1000
ahh and on to trades... i'm very open to trades.. and not just for quad stuff..
some things i'll consider..
250R stuff +2+1 arms, aftermarket shocks
+4 swingarm for a 86-87 R
250R engine
+12 banshee swinger NO LINK
454 big block chevy
350 4 bolt chevy
good soft top for a CJ5 jeep
warn winch 9000# or bigger
sandrail project
35" tires for a 16" wheel E load rating prefered
LCD TV (42" or bigger)
open car trailer (needs to be 7ft between fenders or have drive over fneders.) must have elec brakes or inertia brakes
anything else run it past me.
also for sale..
88 trx250R frame set up for a CR500 engine.. already set up with rubber mounts.. you get whats in the pics.. frame, a arms, spidles, hubs, and front brakes.. $300
87 kawisaki tecate 4.. 310 big bore, head cut for race gas, FMF pipe and silencer, V force reeds, 39 PWK.. runs good just needs some TLC.. but runs and rides just fine.. i also have spare parts for this machines that i'll sell with it (the pipe in the pic is not the FMF that comes with it. its a power pros off my 88 tecate that i am keeping) $1500
This guy has ALOT of banshee stuff. I went there to pick up some parts for my banshee and he has TONS of stuff just ask and he might have it!!! Free Bump
