johstoncounty banshee
Everything posted by johstoncounty banshee
  1. I did not check for warped plates before I installed them. They were brand new in the pack
  2. . My old clutch I cleaned up.
  3. They don't look that Bad to me either I just 2 of them warped really bad it will spring back and forth. My other plates I just recondition them
  4. Well did I just get 2 crappy still plates some how I wonder.
  5. Well I am trying to under stand why just the outside edge is like that and not the whole plate. And then the most inner plate looks new.
  6. Left to right left is inside of basket
  7. OK I will when I get off work.
  8. I tried to post pics off of pH but there to big to upload
  9. The oil smelled cooked but that's from the old clutch where I didn't really get all the old oil out. The fiber look Gd. But you can see the outside edge a lil wore
  10. 421 cub alky CPI. 40 mm carbs
  11. There Gd also. Its just wearing on the outside edge of the plates
  12. Royal purple syncromax. Well I thought the same thing. But everything was aligned properly.
  13. The other one was just wore out. The fibers where smooth. This one here just has me puzzled
  14. No not to me because just maybe a 1/8 of inch is lil gold and light blue. My other clutch held up to probably 100 passes or more.
  15. It has 8 maybe 9 passes. Yea they are burnt now after that happpened. I just pulled them out this pass sat they were a lil golden yellow steels. Still at track I will take pics tomorrow.
  16. To lock the clutch up to keep it from slipping. From the 60 ft on
  17. Billet basket brand new hub. Installed properly.
  18. First pass of the the night. 1/8. 200 lbs static pressure. 15 grams on lock up. Was gonna add more lock up weight but seen plates in the middle where like a fresbie
  19. I was just checked clutch steal plates and they are warped. Its a brand new fast clutch. Not talking junk just curious to no what happened.
  20. Thanks alot. Is Jeff open on Mondays
