papa_smurf49319 Posted March 14, 2010 Report Posted March 14, 2010 Hows this jetting sound for bike in sig 155 main 55 pilot 1-1/2 turns out on pilot 50 degrees right now 500-600 above sea level Quote
banshee332 Posted March 14, 2010 Report Posted March 14, 2010 Hows this jetting sound for bike in sig 155 main 55 pilot 1-1/2 turns out on pilot 50 degrees right now 500-600 above sea level what size carbs and needle. I would think it would need more fuel but get ahold of wesw on here and had a 4mill passion 12 port that put out like 86hp. was not a drag port nither Quote
papa_smurf49319 Posted March 14, 2010 Author Report Posted March 14, 2010 35mm keihens, dont remeber needle off hand, but its in the middle on the clip. Should be the stock needle for those carbs. Ya it really hauls the mail Quote
papa_smurf49319 Posted March 14, 2010 Author Report Posted March 14, 2010 i know theres plenty of guys out there with 4 mills cpis or shearers and 35 pwks. Any help? Quote
locogato11283 Posted March 14, 2010 Report Posted March 14, 2010 did you just get the setup and you are trying to tune it or have you had it for a while and trying to make it run better? these motors are notorious for having a bad dead spot in the midrange with 35mm pwk. Quote
wacko2000 Posted March 14, 2010 Report Posted March 14, 2010 I have a 4mil passion motor with 35mm airstrikers, cpis and I Didnt have a dead spot in the mid range. I sold my air strikers and Im unsure of my jetting but I may be able to find out for you. Are you jetting the bike and having trouble? What are you trying to accomplish by the thread? Are you just looking for a good starting point? Give us some more info> My passion motor runs real strong, Only problems I have is that i cant shift. Quote
MarineNYC Posted March 14, 2010 Report Posted March 14, 2010 I thought U had the tranny done Joe. Quote
papa_smurf49319 Posted March 14, 2010 Author Report Posted March 14, 2010 no dead spot in the mid, little doggy on the lowend but thats to be expected with the shearers. Basically havnt had anywhere to open it up and do a plug chop, went on jims recommendations for jetting and seems to be fine. But i just wanna make sure im in the ballpark and okay to ride it around a little until i can get her to a spot and open it up for plug chop. Seems to run fine, just havnt been able to get outta second or third gear right now. Porcelin looks tan after crusin around for a little bit. Does 155 seem rich or lean? What about the 55 pilot, seems most guys are runnin 50. Cody Quote
DannysZ28 Posted March 14, 2010 Report Posted March 14, 2010 I have that same exact setup and im running a 155-50 jetting but i think jim at passion recommended 152-50 for me and im right at sea level. It seems to be running really strong and i definitely dont have a dead spot in the mid range. Im running the cpi pipes but jim said i should be running the shearers. Quote
wacko2000 Posted March 15, 2010 Report Posted March 15, 2010 Jim told me i would see 6+ hp switching to shearers but i like my cpis so the HP doesnt mean all that much to me. I would just take it somewhere and rip through all the gears and see how it feels. Maybe dropping the pilot will help you with the little bog on the bottom. Quote
Harrisye60 Posted March 15, 2010 Report Posted March 15, 2010 Hi to all this is Harrisye i from WA i just join this forum today.. Quote
DannysZ28 Posted March 16, 2010 Report Posted March 16, 2010 Jim told me i would see 6+ hp switching to shearers but i like my cpis so the HP doesnt mean all that much to me. I would just take it somewhere and rip through all the gears and see how it feels. Maybe dropping the pilot will help you with the little bog on the bottom. Thats what he told me also. He said he saw 6hp increase consistantly on the dyno with the shearers. If i find a good deal or someone that will trade my cpis, i will switch. But for a trail/play bike mine has plenty of power to spare and can really be uncontrollable sometimes on tight trails. Quote
SonOfSand Posted March 17, 2010 Report Posted March 17, 2010 Hows this jetting sound for bike in sig 155 main 55 pilot 1-1/2 turns out on pilot 50 degrees right now 500-600 above sea level I run 140's @ 5000 feet, temps around 50-60, cel needle on 3rd. runs great. Quote
wesw Posted March 26, 2010 Report Posted March 26, 2010 i could offer advise all day but if you dont offer support in the first place it would be an dog chasing his tail ordeal need to know what needle your running. i think your pilot is close 55 58 seems to the sweet spot needle is a toss up. i would suggest a dek, cel but prefer the d series being richer. for a main 150- 155 my guess. jim motors like fuel down low and in the mid range and by doing that you have to lower the main cause it has lot of fuel down low compared to other setups. Quote
papa_smurf49319 Posted March 29, 2010 Author Report Posted March 29, 2010 ok started out with 155's made my way to 162's after three plug chops, smoke ring is chocolate brown but only 1mm wide, not 2mm like it should be. Bike runs really hard! So im thinking im goin to up the mains? gonna try a 165 and then a 170 if i have to, sprayed ether all around the bike so i know theres no air leaks. Quote
