Pappa Kaneda Posted March 2, 2010 Report Posted March 2, 2010 So it's super cold up here and I am worried about my lines freezing. Is it ok to run SeaFoam or Heat through these machines? Quote
esterelbanshee Posted March 2, 2010 Report Posted March 2, 2010 I've ridden at -25 celcius and the lines dont freeze. You might freeze though. It's tough to jet for that temp. Quote
06specialedition Posted March 2, 2010 Report Posted March 2, 2010 I've run sea foam before, it didn't hurt anything...just make sure you don't put too much in. Quote
bansheesandrider Posted March 2, 2010 Report Posted March 2, 2010 (edited) Unless you have water in your gas tank, there is no need to run Seafoam or Heat. You have no more than 6 inches of rubber gas line, there is no metal gas line wth any pockets to hold water on a Banshee and rubber line is much harder to freeze. Edited March 2, 2010 by bansheesandrider Quote
Pappa Kaneda Posted March 2, 2010 Author Report Posted March 2, 2010 Ok thanks. I was not aware of the gas system on these machines. Quote
jbooker82 Posted March 2, 2010 Report Posted March 2, 2010 I believe ISO Heat also has an aditive to help with cold starting. (Permotes evaporation of fuel in a cold engine.) Quote
broncbob Posted March 3, 2010 Report Posted March 3, 2010 I'd guess that you'd see carb icing before your fuel line froze up. Quote
