I bought this bike and it has some aftermarket lights on it but they dont work. They are hooked up to the black wire and the yellow wire. Is there anyway to test the circuts or the lights?
Make sure that you have the headlight switch it the right spot. The black wire is ground and the yellow wire is high beam, green is low beem. The way your bike is wired you lights will only work with the switch in the high beam position.
Ya ive tried in all positions, i dont get it. Im gonna look for my test light and see what i see.
It doesnt seem to have any power at the wire ends. Is there another place i should test up the line like maybe at the dimmer switch or something?
