Snopczynski Posted February 11, 2010 Report Posted February 11, 2010 Why would you have gas puddles from not emptying your float bowls? From bouncing around in the trailer as it travels down the road, or getting tilted up to go in and out of the truck. Or being lifted up by the ends in the shop. Quote
BigMatt Posted February 11, 2010 Report Posted February 11, 2010 if you look at the left side of the stock carbs (left side of bike) you will see a orange/yellow fuel drain hose that runs to the swingarm and drips it to the ground. next to the drain hose on the carb float bowl (the dish lookin thing on the botton of the carb below where your air-filters connect) there is a phillips screw recessed in a hole. if you losen this screw you will see fuel drain out the tube and onto the floor (put a pan under it to catch the fuel) The carb adjustment screws are all flat head screws. so don't go messin with flat heads if your unsure of tuning your carbs... thats what I was thinking was the drain screw, but its only on one side (left) how does it drain the other? thats why I never messed with it because it didn't make sense that it was only on one carb. Thanks for all your help guys! Quote
Burt Reynolds Posted February 12, 2010 Report Posted February 12, 2010 From bouncing around in the trailer as it travels down the road, or getting tilted up to go in and out of the truck. Or being lifted up by the ends in the shop. oh ok i never thought about that actualy Quote
J.J. Posted February 12, 2010 Report Posted February 12, 2010 thats what I was thinking was the drain screw, but its only on one side (left) how does it drain the other? thats why I never messed with it because it didn't make sense that it was only on one carb. Thanks for all your help guys! It's the same on the right carb, you just need a long screw driver. I suggest you remove the carbs the 1st time, if you haven't opened the drains on a regular basis then they will be tough to open. You can't get sufficient push on the screw driver because the boots will flex. Once opened/closed a few times they will be easy to crack open. Quote
HiRoller Posted February 13, 2010 Report Posted February 13, 2010 If I don't think I'll be riding for more than a month I drain the tank and carbs, then dump it in my truck a gallon or two per tank until its gone. Quote
04trinityshee Posted February 13, 2010 Report Posted February 13, 2010 If I don't think I'll be riding for more than a month I drain the tank and carbs, then dump it in my truck a gallon or two per tank until its gone. you put mixed gas in your truck ? Quote
broncbob Posted February 14, 2010 Report Posted February 14, 2010 I normally feed my not so fresh fuel to the lawn mower. But yeah you could feed it to the truck in limited amounts. Quote
Snopczynski Posted February 14, 2010 Report Posted February 14, 2010 Not if it has a catalytic converter. Quote
madjimmax Posted February 14, 2010 Report Posted February 14, 2010 Running it in your vehicle in limited amounts wont hurt a thing with or without a converter. There are plenty of cars and trucks on the road with a shit ton of miles that have blow by due to worn rings and they are still going strong. Quote
MILO Posted February 14, 2010 Report Posted February 14, 2010 (edited) i have never purposely run the carbs dry and don't really see a need to. i was always under the impression it was better to leave gas in it rather than let things dry out. Stabil isn't a bad idea if it's going to sit for a long time but I usually don't use it. The worst case scenario is having to pull the carbs and clean them before the riding season again. Mine basically sits between November - March and I usually don't have any problems getting it going again. I'll drain the old gas and put in new but otherwise it's usually good to go. Edited February 14, 2010 by MILO Quote
Snopczynski Posted February 14, 2010 Report Posted February 14, 2010 Running it in your vehicle in limited amounts wont hurt a thing with or without a converter. There are plenty of cars and trucks on the road with a shit ton of miles that have blow by due to worn rings and they are still going strong. If you want to wear out a catyltic converter, than put 2 stroke gas in your tank. Quote
TwistedSheeRida Posted February 14, 2010 Report Posted February 14, 2010 I just shut it off and turn the fuel off. never leaks i ride it everyday anyways so theres no way im letting the fuel run out everytime. Quote
broncbob Posted February 14, 2010 Report Posted February 14, 2010 If you want to wear out a catyltic converter, than put 2 stroke gas in your tank. Your engine burns oil at all times, the piston rings don't remove all the oil from the cylinder walls, and the incoming fuel charge washes some ofit off and it's burned off during combustion. In limited quantity, 2 stroke oil will not cause damage to converter. Now if you want to fill half of your tank with the stuff, yeah that might be hard on it. All the converter does is burns the unused stuff in exhaust, the only way to trash them is to clog them with crap from combustion, or feed them un-burned fuel. There are ways to un-clog cats as well. Quote
Snopczynski Posted February 15, 2010 Report Posted February 15, 2010 (edited) I will say it one last time before I start whipping out the stats on why you dont do it, why it will ruin a catalytic converter, the people who have taught me why it will ruin a catalytic converter, not to mention the role that those people play in our everyday lives. "dont put 2 stroke gas in the tank of a vehicle with a catalytic converter on it". I shouldn't even have to explain this. Edited February 15, 2010 by Snopczynski Quote
papa_smurf49319 Posted February 18, 2010 Report Posted February 18, 2010 (edited) Your engine burns oil at all times, the piston rings don't remove all the oil from the cylinder walls, and the incoming fuel charge washes some ofit off and it's burned off during combustion. In limited quantity, 2 stroke oil will not cause damage to converter. Now if you want to fill half of your tank with the stuff, yeah that might be hard on it. All the converter does is burns the unused stuff in exhaust, the only way to trash them is to clog them with crap from combustion, or feed them un-burned fuel. There are ways to un-clog cats as well. Putting two stroke in a vehicle that is equipped with a catalytic converter or a diesel particulate filter will infact have ill effects on it. Now how long down the road these effects show up is a different story. Now on my cavalier i have a gutted cat and i can enjoy the wonderful smell of 927 during the winter. lol However amsoil does make a synthetic premix that is safe for cats so maybe there are others also. Cody Edited February 18, 2010 by papa_smurf49319 Quote
