smokin 421 Posted February 5, 2010 Report Posted February 5, 2010 has anybody ever used one of these i need to get rid of my 200w ricky stator and need the wattage for lighting. Is there any body else who makes the high output stators besides lazerstar and are the moose stators any good? thanks Nick Quote
jbooker82 Posted February 5, 2010 Report Posted February 5, 2010 has anybody ever used one of these i need to get rid of my 200w ricky stator and need the wattage for lighting. Is there any body else who makes the high output stators besides lazerstar and are the moose stators any good? thanks Nick If you absolutly need a high out put stator I would run a Ricks Motorsport Electrics stator. The down side is that they are expensive. You get what you pay for. If dont want to break your wallet out then chances are what ever brand of stator you get is going to come from the same place, tiwan or china. Quote
So Cal Suspension Posted February 5, 2010 Report Posted February 5, 2010 If you absolutly need a high out put stator I would run a Ricks Motorsport Electrics stator. The down side is that they are expensive. You get what you pay for. If dont want to break your wallet out then chances are what ever brand of stator you get is going to come from the same place, tiwan or china. Moose has always made halfway decent things. I guess if you don't mind tearing your bike apart if it breaks, give it a shot. Just make sure they have a decent warranty, and won't deny the warranty for stupid reasons. Quote
jbooker82 Posted February 5, 2010 Report Posted February 5, 2010 I have done that twice with ricky stator's. Both were on dune trips from nebraska to little sahara in oklahoma. You cant exactly run back home to get what you need. I was just gald I had an OEM as a backup. I wont run anything but an oem. I shelled out 300 bucks to get a bran spanking new one as a back up. It isnt worth the head ache for me. Quote
Snopczynski Posted February 5, 2010 Report Posted February 5, 2010 Isn't the moose a dual output that uses two regulators? Quote
fastbanshee8 Posted February 5, 2010 Report Posted February 5, 2010 Isn't the moose a dual output that uses two regulators? Yes it is, and I've had one for close to 8 years, with no problems at all. Quote
jbooker82 Posted February 5, 2010 Report Posted February 5, 2010 Isn't the moose a dual output that uses two regulators? Yes I believe so. So you might get away with running it and not having any problems. You will have to run dual regulators and dual circuits to use the full 250 watts. Quote
smokin 421 Posted February 5, 2010 Author Report Posted February 5, 2010 If you absolutly need a high out put stator I would run a Ricks Motorsport Electrics stator. The down side is that they are expensive. You get what you pay for. If dont want to break your wallet out then chances are what ever brand of stator you get is going to come from the same place, tiwan or china. price isnt an issue just want to get the best one out there and not have any problems. is the ricks motorsport made in the US? im not sure how to run the dual regulators is it pretty easy to do? Quote
fastbanshee8 Posted February 5, 2010 Report Posted February 5, 2010 Buy the Moose stator, and an extra regulator. Like I said before, I've had mine for 8 + years, and I've had no problems at all. If you need the extra lighting power, you can't go wrong with this set-up. Quote
smokin 421 Posted February 5, 2010 Author Report Posted February 5, 2010 Buy the Moose stator, and an extra regulator. Like I said before, I've had mine for 8 + years, and I've had no problems at all. If you need the extra lighting power, you can't go wrong with this set-up. ok how do you wire up the second regulator and do you just get another stock regulator? Quote
broncbob Posted February 5, 2010 Report Posted February 5, 2010 Any Idea what the output on either of these stators are at idle? Quote
AKheathen Posted February 7, 2010 Report Posted February 7, 2010 at idle-well it really depends on your idle, but they should be around 50% +/- 10% and just off idle, you will get in the 70% range, and pretty much full power when you are in the pipe... Quote
