theoriginal87 Posted January 8, 2010 Report Posted January 8, 2010 (edited) I have a set of pro curciut platnium pipes and they are alittle faded and have some rust spots and was wondering the best way to polish and restore them?? p.s. the $ was supposed to be & Edited January 8, 2010 by theoriginal87 Quote
ltd.yfz Posted January 9, 2010 Report Posted January 9, 2010 On my sst's i used steel wool and wd-40 and alot of rubbing. Quote
TwistedSheeRida Posted January 9, 2010 Report Posted January 9, 2010 on my ssts i used clr some scotch brite rubbed it on the ruff spots and wiped it away with a rag after it set for a while. Quote
madjimmax Posted January 10, 2010 Report Posted January 10, 2010 Blue Magic metal polish is the shit. I used it on my wheels and my pipes and it did a number to both. Just follow the directions on can. You can get it at any auto parts store and it works on any metal or chrome. My wheels had that white look that they get and my pipes had little rust spots and where dull as hell. I probably could of got them better but I didnt feel like taking the time because I knew that this winter it was in for a tear down. Now that everything is apart I'll hit them again. Quote
bbcmudtruck Posted January 13, 2010 Report Posted January 13, 2010 0000 steel wool and WD. When you get all of the rust off, go back and polish with some sort of metal polish. I usually have good luck with Mothers. If you want to spend a little more money on polish, Semi Chrome is the shit. Quote
BOOZER2009 Posted January 17, 2010 Report Posted January 17, 2010 if you got alot of rust. Bundle up a bit of aluminum foil and dip it in non diet coke and rub off rust. it works killer Quote
SandmanPNW Posted January 18, 2010 Report Posted January 18, 2010 I would like to announce that this is my first post on HQ although I always look stuff up by confirming that Blue Magic is the shit. A polishing bit on a drill w/ the magic and boo yeah. You won't regret it. Quote
SD1026 Posted February 21, 2010 Report Posted February 21, 2010 (edited) I have a set of pro curciut platnium pipes and they are alittle faded and have some rust spots and was wondering the best way to polish and restore them?? p.s. the $ was supposed to be & i am def in the same boat as you. i am just going to bite the bullet and chrome my pc's and the silencers. it is just worth it in the long run for looks,maintenance and cleaning. i am getting prices of like 300.00 Edited February 21, 2010 by SD1026 Quote
themuffinman Posted February 26, 2010 Report Posted February 26, 2010 my buddy has a sand blaster so i'm going to give that a shot. My pipes were rusted so I tried using a DA on it which worked but I think the sand will give it a better look. I can send you some pictures when I finish it if your curious. Quote
