wadlesw96 Posted December 30, 2009 Report Share Posted December 30, 2009 Hi im new to this site and banshee's. I have a 96 banshee with a trinity 2 into 1 carb, v force 3 reeds, bored .04 over, fmf pipes, 19cc domes, and some other stuff. Anyway heres what happened i started it up today and it was fine, then my dad rode it and being a pussy he never got on it much and had it bogged down most of the time. Then i rode it and got it stuck in some deep snow and it sat there idling for a while then it just died. then it wouldnt start very well and wouldnt unless you got on the gas. Ever since it just doesnt seem to run rite. Smoke comes out of the right pipe with alot more pressure than the left and the right header is really hot like it should be and the left one just gets warm (you can touch it with your hand and it doesnt burn or anything) im not sure if its just loaded up really bad or what. please help thanks Quote Link to comment Share on other sites More sharing options...
Idontknowwhy Posted December 30, 2009 Report Share Posted December 30, 2009 What did your plugs look like? Not sure where you're at, but did you rejet for colder weather? Try a new set of plugs, it'd be a good idea to do a compression test too. Quote Link to comment Share on other sites More sharing options...
98_shee Posted December 30, 2009 Report Share Posted December 30, 2009 (edited) Welcome to BHQ Put new plugs in it, clean the carb. Try switching the plug wires to see if the problem follows to the other side. What octain fuel are you running? With the 19cc domes you may need 50/50 race fuel and 93 octain. Do a compression test to see if you need higher octain fuel. Edited December 30, 2009 by 98_shee Quote Link to comment Share on other sites More sharing options...
wadlesw96 Posted December 30, 2009 Author Report Share Posted December 30, 2009 I havnt really checked it out the plugs or anything yet but they are fairly new i think. the guy i got it from said run 93 octane so thats what im running Quote Link to comment Share on other sites More sharing options...
wadlesw96 Posted December 30, 2009 Author Report Share Posted December 30, 2009 Ok i went out switched the wires and it ran fine then i got stuck again and i let it idle while i pulled it out then it started not getting power on the right side. so i let it sit for awhile and switched the wires back to normal and now it runs fine. I guess these things just dont take much to load up idk Quote Link to comment Share on other sites More sharing options...
Idontknowwhy Posted December 31, 2009 Report Share Posted December 31, 2009 Seems like it's chasing that one wire, could be cap or coil. I'd get new plugs anyways, to see where your jetting is at, Also again a compression test, never hurts to check. Get a clymers manual, they're $30.00, and sooner or later (probably sooner), you're going to need it. electrical: http://www.dfn.com/benkaren/elecfaq.html jetting http://www.dfn.com/benkaren/jetfaq.html Quote Link to comment Share on other sites More sharing options...
wadlesw96 Posted December 31, 2009 Author Report Share Posted December 31, 2009 thanks for the advice. as i understand it one of the plug wires isnt allowing enough current to whichever plug it is attached to. what i dont understand is why it runs fine now though since i switched them back? also, this is kind of random but what premix would you recommend 40:1 or 32:1 Quote Link to comment Share on other sites More sharing options...
98_shee Posted December 31, 2009 Report Share Posted December 31, 2009 What oil are you running? Quote Link to comment Share on other sites More sharing options...
LS1Inferno Posted December 31, 2009 Report Share Posted December 31, 2009 yeah it sounds like you have a wire or cap problem, if its not getting enough spark to one side it will have weak spark load up and foul the plug. when you switch them it clears up the plug that was bad, and fouls the other. You can change the caps, or just buy a good used coil with caps on fleabay. Quote Link to comment Share on other sites More sharing options...
wadlesw96 Posted December 31, 2009 Author Report Share Posted December 31, 2009 Ya one of the caps doesnt seem to really snap on the plug when you press it on. so basically is the to fix my problem just new caps/coil and plugs? Also the oil i am using is Ti Lube 2 stroke synthetic 32:1 Quote Link to comment Share on other sites More sharing options...
swrbansheeboy Posted January 3, 2010 Report Share Posted January 3, 2010 Ya one of the caps doesnt seem to really snap on the plug when you press it on. so basically is the to fix my problem just new caps/coil and plugs? Also the oil i am using is Ti Lube 2 stroke synthetic 32:1 just an idea, but have you looked inside the cap to make sure you dont have an old spark plug top stuck in there thats not allowing you to get the cap snapped onto the plug properly? seen that a couple times before, top comes off of the plug and lodges into the cap but works fine untill you change plugs. then you end up with the old plug top lodged in the cap with a new plug with another top installed thats now in the way of the cap snapping on. it's worth a shot... Quote Link to comment Share on other sites More sharing options...
