btbrsio Posted December 30, 2009 Report Posted December 30, 2009 Hi everyone, just found this site and i am very impressed with everyones knowlodge on here. I have an 05 shee thats pretty much stock other then the fmf pipes and some bling bling. just wondering about a few thing i have seen like 4mil. what is this. also would like so advice on big bore kits what all do you need to do to the motor if you do a big bore kit i found one on ebay thats a 421cc kit but only has the pistons rings and gaskets. my motor is all stock and after 4 yrs of riding shes just not as scary as it was when i got it might just be getting use to it i guess but i think its time to build it alittle more. any advice would be appreciated. Quote
4strokekilla1987 Posted December 30, 2009 Report Posted December 30, 2009 Hi everyone, just found this site and i am very impressed with everyones knowlodge on here. I have an 05 shee thats pretty much stock other then the fmf pipes and some bling bling. just wondering about a few thing i have seen like 4mil. what is this. also would like so advice on big bore kits what all do you need to do to the motor if you do a big bore kit i found one on ebay thats a 421cc kit but only has the pistons rings and gaskets. my motor is all stock and after 4 yrs of riding shes just not as scary as it was when i got it might just be getting use to it i guess but i think its time to build it alittle more. any advice would be appreciated. welcome to the site before anything what kinda of riding do you do? a 4mil is a crank that goes 2mm higher and 2mm lower thus giving you more power and for a 421 kit you will need to get a 4mil crank, bigger carbs, a cool head, better pipes, reeds, pod filters, change gearing. lockup with cover, you might want to get it ported and also make it run on race fuel, ohh and also if you want just a little more power why not just port it and put a 4mil crank? you will save alot money by doing that. Quote
btbrsio Posted December 30, 2009 Author Report Posted December 30, 2009 welcome to the site before anything what kinda of riding do you do? a 4mil is a crank that goes 2mm higher and 2mm lower thus giving you more power and for a 421 kit you will need to get a 4mil crank, bigger carbs, better pipes, reeds, pod filters, change gearing. lockup with cover, you might want to get it ported and also make it run on race fuel hey thanks for the info. i live in iowa and there are only 2 park that i ride rock bluff and rathbun there are some really good trails and tracks at rock bluff you can do just about any type of riding there but rathbun is wooded trails with a small track to race around on. sounds like i would be better off not doing the big bore kit. what would some simple mods be for the riding i do? Quote
4strokekilla1987 Posted December 30, 2009 Report Posted December 30, 2009 hey thanks for the info. i live in iowa and there are only 2 park that i ride rock bluff and rathbun there are some really good trails and tracks at rock bluff you can do just about any type of riding there but rathbun is wooded trails with a small track to race around on. sounds like i would be better off not doing the big bore kit. what would some simple mods be for the riding i do? yea for your type of riding a 421 would not be good thats to much power for trails, for your type of riding i would recomend a good trail port and if you want the extra speed get a 4 mil crank and bigger carbs and mill your stock head http://www.herrjugsracing.com/Porting_Motor_packages.html Quote
btbrsio Posted December 30, 2009 Author Report Posted December 30, 2009 hey thanks killa sound like a good idea. love the statement above your pic. i had a friend that thought the same thing on his 450 boy was he suprized L.O.L if he would have tradeed hes palaris for a 2 stroker instead he might have been alittle closer at the finish line. Quote
locogato11283 Posted December 30, 2009 Report Posted December 30, 2009 id probably go with a 4mm stock cylinder set up. you will make awesome power that will work well with your type of riding. go with some keihin 33mm pwk, noss head to bump up compression, timing advance etc... how much do you wanna spend? that will ultimately affect your mod decisions. also, welcome to HQ Quote
btbrsio Posted December 30, 2009 Author Report Posted December 30, 2009 i have big dreams an empty pockets L.O.L since i lost my job 8 months ago. started rebuilding some old bikes for friends to make some cash but never any mods some im new to it mostly do stock restos. so i will probly get the shee cleaned up and lookin purdy again i have it completely disassembled in the basement now. havent done much to it since i got it other then grease it before going riding and washing it off after (sometimes) hey what would bring the shine back to the fenders? Quote
alf44 Posted December 30, 2009 Report Posted December 30, 2009 Welcome dude. A good port job advanced timing and some bigger carbs would be a great start. You will notice a huge difference. There some great motor guys on here that are also sponsers. Hit them up when your ready. All of us site sponsors do are best too offer you great advice, pointers and services. So dont be scared to ask. You can always pm us also anytime. Welcome too your new addiction dude. Quote
spurdy Posted December 31, 2009 Report Posted December 31, 2009 Welcome bro. You could port your existing cyls. Since you've done nothing to them they should be on stock bore (64mm) they have all their life left in them. If you think you may go to a 4 mil down the road then I would do it now. Depending on who does the porting and what kind you may not be able to change from stock stroke to 4 mil in the future. Advancing the timing will wake her up even on stock stroke with stock porting. That is cheap and easy. Timing plate is 35$ off ebay or you can mod you stock plate. Bigger carbs are an option but stockers can run well also. A Noss head to control your compression. Higher compression will typically increase you low end but at some point you will need to increase your octane to prevent detonation. Good luck! SP Quote
2/2 many banshees Posted January 1, 2010 Report Posted January 1, 2010 Stick around you'll love what we can do for your banshee.( The sponsors are great here and will have your bike ripping in no time.) Quote
btbrsio Posted January 1, 2010 Author Report Posted January 1, 2010 thanks for all the great advice. think i will do the reedkit, timing plate, K&N filters pods, rejet, and the tors elim. kit Quote
btbrsio Posted January 1, 2010 Author Report Posted January 1, 2010 heres a pic getting ready to start blasting and repainting i will add new pics as they are taken Quote
