longmont Posted December 26, 2009 Report Posted December 26, 2009 I just got a new shee now it wont start. I pulled off the tors and put a twist throttel on. New duel stage reeds, and a boost bottel. Also put pro circut pipes on. I was told to rejet it with 305 and 27.5. I live at about 5000 feet. Got everything put togeather and there was no spark. If I plug in the thumb throotel theres spark but shee wont fire up at all. Nuthing !When I got her it ran. All stock. Quote
FrankieSquid Posted December 26, 2009 Report Posted December 26, 2009 I just got a new shee now it wont start. I pulled off the tors and put a twist throttel on. New duel stage reeds, and a boost bottel. Also put pro circut pipes on. I was told to rejet it with 305 and 27.5. I live at about 5000 feet. Got everything put togeather and there was no spark. If I plug in the thumb throotel theres spark but shee wont fire up at all. Nuthing !When I got her it ran. All stock. If i was you i would take the time and take out your whole harness and cut out the tors bullshit. There is a switch at the thumb throttle and one in each carb just follow the wires and cut them at the harness for a cleaner look. Your going to need to get the TORS removal kit, something cheap on e-bay. TORS is notorious for "no start" issues. Quote
eb2flyz Posted December 27, 2009 Report Posted December 27, 2009 I just got a new shee now it wont start. I pulled off the tors and put a twist throttel on. New duel stage reeds, and a boost bottel. Also put pro circut pipes on. I was told to rejet it with 305 and 27.5. I live at about 5000 feet. Got everything put togeather and there was no spark. If I plug in the thumb throotel theres spark but shee wont fire up at all. Nuthing !When I got her it ran. All stock. there is a little black box above your left hand pipe, just disconnect that and you should be up and running Quote
GrMeyer Posted December 28, 2009 Report Posted December 28, 2009 there is a little black box above your left hand pipe, just disconnect that and you should be up and running +2 on the black box... I forgot about it when I did my tors. Also, they dont make jets in 5's. They go in 10's Also as for a starting point of jetting. We need to know if you still have the air box on. If so are there any mods done to the lid? And what temps are u running in. Also take the boost bottle and hit it with a hammer and put the stock tube back on. Quote
longmont Posted December 28, 2009 Author Report Posted December 28, 2009 +2 on the black box... I forgot about it when I did my tors. Also, they dont make jets in 5's. They go in 10's Also as for a starting point of jetting. We need to know if you still have the air box on. If so are there any mods done to the lid? And what temps are u running in. Also take the boost bottle and hit it with a hammer and put the stock tube back on. It does have a air box but no lid. Shee wont even act like shee wonts to start that cant be from jets could it ?. And I put a 310 jet sorry but thanks for the corretion. Whats the prob with a boost bottel Quote
eb2flyz Posted December 28, 2009 Report Posted December 28, 2009 It does have a air box but no lid. Shee wont even act like shee wonts to start that cant be from jets could it ?. And I put a 310 jet sorry but thanks for the corretion. Whats the prob with a boost bottel disconnect the tors brain (little black box) and you should be up and running. the boost bottle from what I've read and other peoples experience is that it doesn't make any difference and that the extra weight is known to crack the manifolds and cause a lean condition (ie bang go's the motor if you don't catch it in time) Quote
longmont Posted December 29, 2009 Author Report Posted December 29, 2009 disconnect the tors brain (little black box) and you should be up and running. the boost bottle from what I've read and other peoples experience is that it doesn't make any difference and that the extra weight is known to crack the manifolds and cause a lean condition (ie bang go's the motor if you don't catch it in time) I got the black box disconnected and still couldent get her started. Not sure if its cuz its only 15 degrees or what but I probable kicked on it for 20 min. Quote
AKheathen Posted December 29, 2009 Report Posted December 29, 2009 tit you try fresh/clean plugs? are your float bowls on the correct carb, they can be mixed up.... is your choke tube on?. pull your filter and cover the hole with your hand, and see.......if it starts, your choke is not working right. make sure you are jetted for that cold....... Quote
longmont Posted January 3, 2010 Author Report Posted January 3, 2010 tit you try fresh/clean plugs? are your float bowls on the correct carb, they can be mixed up.... is your choke tube on?. pull your filter and cover the hole with your hand, and see.......if it starts, your choke is not working right. make sure you are jetted for that cold....... not sure if the bowls are on the right side. How can i tell do I need to pull them back off? Not sure what the choke tube is Quote
volcrano Posted January 3, 2010 Report Posted January 3, 2010 not sure if the bowls are on the right side. How can i tell do I need to pull them back off? Not sure what the choke tube is the bowl with the brass bb at the bottom goes on the carb with the choke pull lever.the choke tube is the little piece of fuel line/vacuum hose that connects the two carbs together so when u choke the left-it chokes the right.check to see if u have spark!!!!!!put a known firing plug in ur spark plug cap and lay it on the head.if u have spark and u know ur motor is tight-u have a fuel issue.i hope u got spark and are just missing ur choke tube-easy fixes are nice. Quote
longmont Posted January 3, 2010 Author Report Posted January 3, 2010 the bowl with the brass bb at the bottom goes on the carb with the choke pull lever.the choke tube is the little piece of fuel line/vacuum hose that connects the two carbs together so when u choke the left-it chokes the right.check to see if u have spark!!!!!!put a known firing plug in ur spark plug cap and lay it on the head.if u have spark and u know ur motor is tight-u have a fuel issue.i hope u got spark and are just missing ur choke tube-easy fixes are nice. choke tube was off fired right up thanks guys Quote
juan1 Posted January 3, 2010 Report Posted January 3, 2010 what is the benefit of eliminating the tors? Quote
AKheathen Posted January 4, 2010 Report Posted January 4, 2010 well, aside from cleaning things up nicely, it simplifies and leaves less things to break. also alot easier to change jets or remove the carbs, and relieves some mass that tends to contribute to intake cracking... Quote
