T_Shee Posted November 10, 2009 Report Share Posted November 10, 2009 so my stock basket cushions are beyond worn out and im too cheap to buy a billet basket right now. my question is can you change them on a stock basket? i saw the how to about going to a billet basket and saw how they use bolts to fasten the basket to the gear after the rivets are removed but are the stock basket holes tapped or is that just for aftermarket? also i cant find a kit that comes with the bolts. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted November 10, 2009 Report Share Posted November 10, 2009 The factory basket is not drilled and taped. I think you would ruin the basket trying to remove the rivits. If your to cheap to buy a billit basket then find a used one that is still good. Quote Link to comment Share on other sites More sharing options...
87sheerips Posted November 10, 2009 Report Share Posted November 10, 2009 Get a MAGNUM basket from FAST. Its like $150, problem solved Quote Link to comment Share on other sites More sharing options...
T_Shee Posted November 11, 2009 Author Report Share Posted November 11, 2009 ok guys thanks Quote Link to comment Share on other sites More sharing options...
Thewhite Posted November 11, 2009 Report Share Posted November 11, 2009 Get a MAGNUM basket from FAST. Its like $150, problem solved did I need to keep the big outter oring to install it on the magnum basket or I can discard it. thanks Quote Link to comment Share on other sites More sharing options...
uwenr Posted November 11, 2009 Report Share Posted November 11, 2009 so my stock basket cushions are beyond worn out and im too cheap to buy a billet basket right now. my question is can you change them on a stock basket? i saw the how to about going to a billet basket and saw how they use bolts to fasten the basket to the gear after the rivets are removed but are the stock basket holes tapped or is that just for aftermarket? also i cant find a kit that comes with the bolts. You can replace them, you have to drill the rivots out either way billet basket or replacing the cushions. http://vitosperformance.com/atv_parts/product.php?productid=11178&cat=184&page=1 Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted November 12, 2009 Report Share Posted November 12, 2009 (edited) You can replace them, you have to drill the rivots out either way billet basket or replacing the cushions. http://vitosperformance.com/atv_parts/product.php?productid=11178&cat=184&page=1 No you can't, the "rivet" on the stock basket is actually cast into the basket, after the factory put the gear, cushions and backing plate on they peen the remaining metal sticking out into a head to hold everything together. If you could locate the holes properly you could drill all the way through the basket, countersink the holes on the inside, and bolt it back together, BUT you would have to get the holes in EXACTLY the right place. Edited November 12, 2009 by bansheesandrider Quote Link to comment Share on other sites More sharing options...
