Minkia38 Posted October 27, 2009 Report Posted October 27, 2009 Frame components J Frame $750.00 (titled add $100), A-arm frame, $225 (titled add $100), Steering stem $30.00 A-arms / J-arms with brakes, hubs, spindles, and tie rods $300.00 Swingarm $40.00 Axle $100.00 Bearing carrier $60.00 Footpegs $10.00 Nerf Bars / Metal Heel guards $60.00, add $50 for plastic heel guard pieces Rear Hubs $40.00 Rear Sprocket & Hub $15.00 Rear Brake disc & Hub $15.00 Dogbone $10.00 Rear Grab Bar $20.00 Front Bumper Pushbar $50.00 Shifter $10.00 Skid Plate $20 Running Engine $1000.00 Rubber intake boots/Boost $30.00 Reeds and cages $20.00 Carbs and cable $100.00 Airbox (or air filter) $50.00 - $80.00 Kickstarter $50.00 Gas Tank $30.00, $15 for one with bad fenders mounts Pipes $35.00 stock - $300.00 chrome aftermarket motor parts: cylinders $300 crank $175 shift drum, rods, forks $25 gears/tranny $130 cases $150-$200 clutch cover $30 stator cover $ 15 stator & timing plate $80-$100 internal bolts $25 head $15-$35 flywheel $75-$100 Plastic Front & rear Fenders $100 - $300 Radiator Plastic $35 Gas Tank Plastic $35 Seat w/ latch $40-$100 Fender brackets $15 Electrical CDI Box $60.00 Wiring harness / Loom $30.00 - $60.00 Coil $30.00 Headlights $80.00 on/off switch $25.00 Key w/ plastic housing $35.00 Taillight $20.00 Misc Rear brake setup $110.00 Bolt set $20.00 Rear Shock $75.00 Front shocks $90.00 Front tires & rims $100.00 varies Rear tires and rims $100.00 varies Handlebars & grips $10.00, aftermarket $20 Clutch lever / perch $10.00 - $20.00 Thumb Throttle assembly $30.00 Radiator & Reservoir & lines$25.00 Radiator only- $20 Front brake lines $10.00 Front brake lever/rezzy $15.00 Motor Mounts $10.00 or check out my auctions: http://stores.ebay.com/Motor-City-ATV?refid=store Quote
bad 350 shee Posted November 5, 2009 Report Posted November 5, 2009 750 for a j arm frame that fuckin nuts Quote
grandnational Posted November 5, 2009 Report Posted November 5, 2009 750 for a j arm frame that fuckin nuts all these prices are.. Quote
01strokedshee Posted November 5, 2009 Report Posted November 5, 2009 what the hell r u smoking 750 for a J ARM FRAME THATS FUCKING NUTS Quote
ELKARACING_SHEE Posted November 5, 2009 Report Posted November 5, 2009 (edited) yeah he's obsiously made a type-o, no offence man but some stuff is wayyy to over priced Edited November 5, 2009 by ELKARACING_SHEE Quote
quadicted Posted November 5, 2009 Report Posted November 5, 2009 International shiping is the same from givraltar to australia. Thats fucking crazy ! Quote
stokes77 Posted November 6, 2009 Report Posted November 6, 2009 Not to mention the parts you get from him are crap. I had a big issue with this guy on eBay a while back and ended up sending the item back... he actually filed a non paying bidder claim on me... after I had paid for, received the item, and sent it back, because I disputed the item via pay pal. A quick review of his feedback on eBay will show you I'm not the only person this guy pulls bullshit stunts with. I know this guy has been around here a long time and has probably had a lot of customer's that were happy, but in my experience I would stay away. Quote
