I was riding my shee the other day and it dropped a cylinder so I figured I had fouled a plug. I put two new plugs in and had the same problem, it would start up fine and run on the right cylinder really strong and the left one would just fire every now and then spiratically. I removed both carbs and cleaned them. Put them back on and nothing changed. I swapped plug wires and still no difference. Both cylinders have good compression. If I pull the plug from the problem cylinder after letting it run for a minute the plug is perfectly clean and bone dry. It seems like a fuel problem to me but I dont know what else to try. Anybody have any suggestions?
I wouldn't know what exactly is causing the problem but the way I troubleshoot is pulling things apart till I find something that's not correct.. I would start at the carburetor. Soak it in the carb cleaner dip you can buy. Maybe pull the bowl off and check the jets and see if they're clogged. Make sure the reeds flex a little (maybe they're sealed shut somehow)? Hope that helps a little.
I completely tore down the carbs. Removed and cleaned the jets, and fully cleaned the internals of the carbs with carb cleaner. The reeds all seemed fine. I am not sure what next to look into.
I had the same issue just a few days ago. I had a fresh top end, reeds and carb rebuild. Still running on one cylinder. Since dune season was so close, I just took it into the shop instead of fooling around with it and risk not having my bike ready. They synced and adjusted the carbs and it now runs great! I was stumped too!
try unpluging the tors box under the tank if you still have it i had the same prob and that worked for me
I dont have the tors system anymore.
I did sync the carbs after cleaning them but I am not sure of what else there is to adjust on them
So the carbs are perfect and you put new plugs in and the reeds are fine.. Pull the plug out and check if it's even getting spark. I believe in order to do that you pull both plugs out and kick it a few times and look at the end of the spark plug when you kick it and see if the spark jumps at the tip. Give that a try and let us know how it goes.
I checked and confirmed I have spark. I switched the plug wires to see if the problem moved to the other side and it didn't so I believe that eliminates the coil being the problem.
Alright guys today I pulled the carb back off and took out my reed cage to ispect double check that none of them where stuck. The reed looked fine and all of them moved. I put it back together and started it ran on both cylinders for about 15 seconds and then dropped the cylinder again. I can't figure it out.
I I have determined it is a spark problem. The cylinder would not fire even with starting fluid sprayed directly in the cylinder and I am getting unburned fuel out of that exhaust pipe. I am planning on replacing my coil and seeing if that fixes my problem.
