I have RIS desighn headlights that are basically like trail techs... they use the MR16 hallogen lights....
i was wondering if i could just buy the trail tech SCMR16 HID 30watt spot and plug it in? :blink:
do the HID draw more amp? will i have to rewire at all? :confused:
has anyone done this before??
thanks in advance guys...
you need to run dc conversion with a battery to power hid ballasts
do you know how much this conversion would cost?? and where i could find it?? :confused:
what kind of battery would i have to have? :blink:
I have a dc conversion done to my bike, and I run DC led lights for night. Costs varies greatly depending on your battery size and the parts you use.....Like reg/rec, connectors, circuit breakers, etc.....
I run a stock stator with the conversion. It is very difficult finding the ground on a stock stator to float it.
I did this a couple of years ago but haven't been able to get out to the dunes much to try it out
due to performance issues.
I started out with an Ricky Stator unit with the ground floated already so it was a simple bolt-on
deal. I cleaned up the harness to simplfy it. The TORS was already removed when I bought it
so I removed all the un-needed wiring.
I have an 8.5" Vision X HID for the dunes and a 30 watt Trail Tech flood for cruising around camps.
I wired a relay for each light off of the stock light switch; low beam for Trail Tech, high beam for HID.
I cut out the tool kit holder and radiator reservoir and a buddy made a battery box from aluminum.
I'm happy with the whole thing for the most part. I'll be even happier when I get my shee running right.
Pulling the RS stator and putting the stocker back on for now to determine if it's the stator that's bad
like other here have found.
You can still use the factory one. Your gonna need to be fairly handy with wiring tools, and able to understand a factory wiring diagram though.
