Snopczynski Posted October 5, 2009 Report Posted October 5, 2009 I run bone stock cages. Needles for which carbs? I run mikunis. Everyone here seems to be talking about pwk's though. Quote
Sammy Posted October 5, 2009 Report Posted October 5, 2009 http://bansheehq.com/forums/index.php?showtopic=120479 There's a link on porting stock cages with some good tips also. Quote
volcrano Posted October 5, 2009 Author Report Posted October 5, 2009 so what makes the stock cages with 2 stage reeds better than v3s?i just dont wanna dick around and spend money if i feel no difference?oh-snoop-how do u like ur tm 28s?again with this-is going from a 26 to 28 flatslide gonna make a difference u can feel??if so-i might look into a tm.u can get them brand new for 250-and i dont gotta spend another 1000 on jets for a keihin.ive got ass loads of jets from my tm 34s.i think the pilots are even the same.can i get pros and cons on switching reeds and carbs.i really do appreciate the help guys.snoop-u da man-sammy thanks for the ported cage post.rajuncajun-i think the norn around here is the cel needles. Quote
Snopczynski Posted October 5, 2009 Report Posted October 5, 2009 I like the tm's alot. You will feel a difference going from stock to those. The pilots are not the same from stock to tm's. If you buy TM's, the nozzle, slide, mains, needles, and pilots all have to be a certain size to make the banshee run right. The vf3's are a high flow cage, and they work well at high rpm. The pc's will limit your max rpm so the bolt on petals will make the power curve work better for you at low rpm. Quote
RagunCajun Posted October 5, 2009 Report Posted October 5, 2009 I meant what mains, not needle. my mistake. Quote
