hey guys
i've been running the YFZ front end for a while now but was curious to know if anyone had gone over the geometry of the set-up. the reason im asking is because im ready to drop some coin on a set of shock but if a set of +2+1 or +3+1 standard travel banshee arms will give me a better smoother more consitant ride i would get a set of banshee arms and shocks rather then keep the 450 arms.
so like i said, has anyone checked out the geometry and compaired it to a standard or long travel set of banshee arms?
or has anyone switched from 450 arms back to + banshee arms and what do you think about them.
cheers
I switched from +2+1 banshee arms to the yfz450 arms and wish I would have never done it. I'm switching back to banshee arms as soon as I can.
what is the major differences in the handling and ride (what dont you like about them and what do you like about them if anything)
I was originally running Full Flight +2+1 with works dual rates. I came across a really good deal on Elkas that were advertised for a banshee so I bought them. When they showed up, I realized they were for a longer travel banshee. They are 16.5" long so I bought the 450 setup, and they fit perfect. In the trails and track its not real terrible, but I have my bike lowered for Horseshoe and TT raceing. When its lowered it feels like I'm steering a tank. It pushes in the corners and it just hard to turn. At regular ride hieght its the same, just not as bad. Either way you put it, my old setup was alot better. I got ahold of Tim at Steller performance and he can custom build me some arms to fit the longer Elkas, for the same price as off the shelf arms. So thats the direction I'm headed. 450 arms belong on 450s!
was he building +2 arms for those shocks or is he building longtravel aarms
  • 2 weeks later...
CUSTOM YAMAHA BANSHEE FRAME WITH UPPER AND LOWER CONTROL ARMS. FRONT SUSPENSION HAS BEEN MODIFIED FOR YFZ450 SHOCKS AND CONTROL ARMS. SHOCKS ARE NOT
INCLUDED WITH THIS, JUST WHAT IS IN THE PICS. WITH THIS MODIFICTATION, THE FRONT SUSPENSION IS 49" WIDE WITH STOCK YFZ450 CONTROL ARMS. NO SPACERS OR AFTERMARKET
CONTROL ARMS ARE NEEDED TO WIDEN THE BIKE. ALL WELDING HAS BEEN PROFESSIONALLY DONE. FRAME IS 100% STRAIGHT AND HAS NO CRACKS. FRAME HAS BEEN POWDER COATED AT
CUSTOM POWDER COATING OF DALLAS. IT HAS 2 LAYERS OF BLACK WITH 2 LAYERS OF CLEAR. ALL BEARINGS AND SEALS ARE NEW IN BOTH UPPER AND LOWER CONTROL ARMS. STEERING
STEM BEARING AND SEALS ARE NEW ALSO. FRAME HAS SCUFF MARKS WHERE SKID PLATE WAS MOUNTED, OTHER THAN THAT POWDER COAT IS PERFECT. BIKE HAS 6 RIDES TOTAL. MUST SEE
SHOW FRAME. $750 firm. if interested call Steve 972-880-0114
  • 3 weeks later...
where your problem lies is the foreward camber angle. the further the lower ball joint is in front of the upper, the harder it will be to steer. this is because the weight is placed behind the pivot axis of the ball joints. the greater angle improves cornering, while making it harder to turn. inward casterwill also have an effect on turning
