turbo banshee
slowrider660
  • Replies 45
  • Created
  • Last Reply
Top Posters In This Topic
Possible; yes. Easy; no. Expensive; you bet.
If you wanted to do it, go all out. Get an aerocharger, get some R6 throttle bodies, and use Microsquirt to run them. That way there's no messing around with oil pumps, lines, or tanks and no messing with trying to tune blow through carbs.
pain in the ass to tune yes fast as hell when there right you bet stock motor shee with a turbo running right will run 3.7s to 3.8 in 300 ft would love to see one on a 18mill or a tripple seen a trubo shee a sheltons drag strip ran sweet for 2 or 3 passes then re tune it
wouldn't that suck some of the exhaust back into the intake, becasue its causing the roatation.
this turbo thing seems retarded. people have it just to say they have it.
No, there are two turbine's, one is a compressor (intake side) one is a turbine (exhaust side) and they are only connected by a shaft. the shaft is sealed. Look it up some time. It's a pretty simple concept but I'd rather put one on my car than to try and tune a Banshee for it
