Shee starting up in reverse wtf
MRMOONEY
I got this banshee about a month ago I put FMF fattys on it jetted it, pods, everything else is stock.
Sometimes its happened 3 times now when i start it the motor starts in reverse and when you let the clutch out and put it in gear it will acutally move backwards wtf. What can caues this is this a timing issue i pulled the stator cover off and its all stock meaning no adjustable timing plate etc.. please help and thanks in advance
Pull your stator cover and make sure there isn't a timing plate. If their is it may have came loose and retarded your timing. If thats not it it may be your cdi.
I took the cover off and there is no timing plate.
I am going to order a fylwheel pulley and revmove the flywheel ill check the key. I have another bike ill try swapping the CDI's out
