MRMOONEY Posted September 19, 2009 Report Posted September 19, 2009 I got this banshee about a month ago I put FMF fattys on it jetted it, pods, everything else is stock. Sometimes its happened 3 times now when i start it the motor starts in reverse and when you let the clutch out and put it in gear it will acutally move backwards wtf. What can caues this is this a timing issue i pulled the stator cover off and its all stock meaning no adjustable timing plate etc.. please help and thanks in advance Quote
MRMOONEY Posted September 19, 2009 Author Report Posted September 19, 2009 ....there is no reverse I know the motor is starting up in reverse and the shee will move backwards. is this a timing issue or something? Quote
isrsan Posted September 19, 2009 Report Posted September 19, 2009 Yes, it is a timming issue. Is the CDI stock? Quote
98_shee Posted September 19, 2009 Report Posted September 19, 2009 Pull your stator cover and make sure there isn't a timing plate. If their is it may have came loose and retarded your timing. If thats not it it may be your cdi. Quote
hauser2169 Posted September 19, 2009 Report Posted September 19, 2009 mine did this, inorder for me to fix it i got a new cdi and went plus 4 timing Quote
370banshee Posted September 19, 2009 Report Posted September 19, 2009 check the fylwheel key.. it may be sheared and the flywheel as tweaked just enought to throw your timing off to make it fire backwards... it happens on blasters all the time.. it's possible a banshee could do the same thing Quote
Drewski Posted September 19, 2009 Report Posted September 19, 2009 this is called dieseling when this happens to a motor could be the flywheel key or the plate. senn it happen on a mazda pickup once Quote
MRMOONEY Posted September 19, 2009 Author Report Posted September 19, 2009 Yes, it is a timming issue. Is the CDI stock? Yes stock CDI Quote
MRMOONEY Posted September 19, 2009 Author Report Posted September 19, 2009 Pull your stator cover and make sure there isn't a timing plate. If their is it may have came loose and retarded your timing. If thats not it it may be your cdi. I took the cover off and there is no timing plate. I am going to order a fylwheel pulley and revmove the flywheel ill check the key. I have another bike ill try swapping the CDI's out Quote
MDalton Posted September 19, 2009 Report Posted September 19, 2009 Seen this happen on a diesel that pop started itself. The block cracked because the water pump does not work in reverse on a detroit diesel so I would watch out. Quote
Drewski Posted September 20, 2009 Report Posted September 20, 2009 I took the cover off and there is no timing plate. I am going to order a fylwheel pulley and revmove the flywheel ill check the key. I have another bike ill try swapping the CDI's out the timing plate is under the flywheel Quote
flyhighprerunner Posted September 20, 2009 Report Posted September 20, 2009 take a picture there has to be a timing plate, but then again maybe not!!! Quote
MRMOONEY Posted September 20, 2009 Author Report Posted September 20, 2009 the timing plate is under the flywheel I know, what I meant was an adjustable timing plate there is not an adjustable plate on it I mentioned that in the 1st post everything is stock except pipes and pods. Quote
bbcmudtruck Posted September 20, 2009 Report Posted September 20, 2009 Sweet, I wish mine had reverse! Quote
