I got this banshee about a month ago I put FMF fattys on it jetted it, pods, everything else is stock.
Sometimes its happened 3 times now when i start it the motor starts in reverse and when you let the clutch out and put it in gear it will acutally move backwards wtf. What can caues this is this a timing issue i pulled the stator cover off and its all stock meaning no adjustable timing plate etc.. please help and thanks in advance
....there is no reverse
I know the motor is starting up in reverse and the shee will move backwards. is this a timing issue or something?
check the fylwheel key.. it may be sheared and the flywheel as tweaked just enought to throw your timing off to make it fire backwards... it happens on blasters all the time.. it's possible a banshee could do the same thing
Pull your stator cover and make sure there isn't a timing plate. If their is it may have came loose and retarded your timing. If thats not it it may be your cdi.
I took the cover off and there is no timing plate.
I am going to order a fylwheel pulley and revmove the flywheel ill check the key. I have another bike ill try swapping the CDI's out
the timing plate is under the flywheel
I know, what I meant was an adjustable timing plate there is not an adjustable plate on it I mentioned that in the 1st post everything is stock except pipes and pods.
