Michael66 Posted August 26, 2009 Report Posted August 26, 2009 I bought a banshee a month or so ago torn completely apart and rebuilt it. This is my first banshee or any twin 2 stroke for that matter. It fired off the first kick and was running fine on the right cylinder and the left wasn't running. It needed a new throttle cable so i put one on and figured out i had the wrong carb cap and needle assembly on the wrong carb. So i swapped it and the cable and fired it back up and now the left cylinder runs and not the right. If i pull the choke on the left carb the right cylinder starts running. If i let off the choke the left cylinder starts leaking fuel out of the vent on the bottom of the bowl. Please help so i don't have to go to a dealership!! It is like the one with that cap starts hogging all the fuel. Quote
99bansheeboy Posted August 26, 2009 Report Posted August 26, 2009 I bought a banshee a month or so ago torn completely apart and rebuilt it. This is my first banshee or any twin 2 stroke for that matter. It fired off the first kick and was running fine on the right cylinder and the left wasn't running. It needed a new throttle cable so i put one on and figured out i had the wrong carb cap and needle assembly on the wrong carb. So i swapped it and the cable and fired it back up and now the left cylinder runs and not the right. If i pull the choke on the left carb the right cylinder starts running. If i let off the choke the left cylinder starts leaking fuel out of the vent on the bottom of the bowl. Please help so i don't have to go to a dealership!! It is like the one with that cap starts hogging all the fuel. did you sync the carbs? Quote
Michael66 Posted August 26, 2009 Author Report Posted August 26, 2009 I got both of the dots in the windows. What else is there to it? Quote
99bansheeboy Posted August 26, 2009 Report Posted August 26, 2009 I got both of the dots in the windows. What else is there to it? buy nitrotate's instructional video Quote
Michael66 Posted August 26, 2009 Author Report Posted August 26, 2009 Why is it overloading with fuel? And sometimes it will start revving on its own. The clymers doesn't explain well. Quote
Michael66 Posted August 27, 2009 Author Report Posted August 27, 2009 Fiddled with the carbs and now the left cyl is glowing red on the header pipe Quote
pr0blumz Posted August 27, 2009 Report Posted August 27, 2009 (edited) Fiddled with the carbs and now the left cyl is glowing red on the header pipe Did you do a leakdown test to check for air leaks after you put the engine back together? Edited August 27, 2009 by pr0blumz Quote
Havok248 Posted August 27, 2009 Report Posted August 27, 2009 (edited) I bought a banshee a month or so ago torn completely apart and rebuilt it. This is my first banshee or any twin 2 stroke for that matter. It fired off the first kick and was running fine on the right cylinder and the left wasn't running. It needed a new throttle cable so i put one on and figured out i had the wrong carb cap and needle assembly on the wrong carb. So i swapped it and the cable and fired it back up and now the left cylinder runs and not the right. If i pull the choke on the left carb the right cylinder starts running. If i let off the choke the left cylinder starts leaking fuel out of the vent on the bottom of the bowl. Please help so i don't have to go to a dealership!! It is like the one with that cap starts hogging all the fuel. This is the story of my life! im having the same damn problem and honestly im just thinkin new carbs for me Edited August 27, 2009 by Havok248 Quote
Michael66 Posted August 27, 2009 Author Report Posted August 27, 2009 I just bought two more off. Of ebay. Mine look like they have had hard life so I bought better looking ones.I have no idea how they had them set either.mine is blowing fuel out the exhaust too! Quote
99bansheeboy Posted August 27, 2009 Report Posted August 27, 2009 I just bought two more off. Of ebay. Mine look like they have had hard life so I bought better looking ones.I have no idea how they had them set either.mine is blowing fuel out the exhaust too! holy shit i have no clue i would seriously take it to a dealership or a knowledgeable friend Quote
XxMeltIcexX Posted August 27, 2009 Report Posted August 27, 2009 holy shit i have no clue i would seriously take it to a dealership or a knowledgeable friend Do it yourself unless you have loads of money or just don't like knowing how these machines work! Do yourself a favor and learn it. First things first, do a leakdown test. Let us know the results, then we will go to the next step. Oh, and list us the motor components and specs. Eric Quote
Michael66 Posted August 27, 2009 Author Report Posted August 27, 2009 If the new cars don't fix it I will have to. The guy I bought it from bought a bunch of parts a guy had off of several bikes. I'm thinking these carbs were somebody junk. They have leaked gas from day 1. If this fixes me I will let you know havoc Quote
