I've got several parts left over from the last of my bikes and am looking to clean house.
I have a stock 05 yfz frame no bends or cracks with a clear vin, no title, comes with a Bill of Sale. $150
Stock subframe, a couple of the grab bar mounts are loose, still works great and has no distortion or cracks. $40
Stock footpegs and heal guards with Pro Armor Nerfs, black nets. $85
Pro Armor aluminum bumper. $40
Motion Pro twist throttle, comes with cable. $15
Complete stock front and rear suspension.
Stock a arms, shocks, tie rods, brake lines. good bushings/ball joints/seals. $150 Will fit the banshee with some modification as a +2.5 +1 set up.
Stock swing arm, carrier, rear shock good bearings/seals. $120
Stock rear bake set up, caliper, line, master cylinder etc. $40 needs pads
Galfer Wave Rotor on stock disk hub, mint shape. $35
Stock front spindles/calipers/hubs. $100 Also fits the banshee with no modification, increases possible a arm travel and turning, also allows you to run dual piston calipers for improved braking, great upgrade.
Stock Radiator with dent, no leaks or damaged fins. $30
3 sets of stock rear hubs, all splines in mint condition. $10 dollars per set.
Durablue +2+4 adjustable axle all splines in perfect shape, no bends what-so-ever, was painted black and has some chipping. $80
+2+1 Anti Vibe Houser Stem Blue. $110
Stock set of blue plastics, no cracks, some stress marks and scratching cosmetically and front nose piece is missing a mounting tab, still fits on. $75
Stock seat no tares. $25
I will add pics as I have time to, if interested call or text anytime at 713-304-7163 my name's Blake, if you would rather you can also email me at [email protected].
There are probably odd and ends I am forgetting so if you're curious if I have something not listed just ask. I also have a Complete banshee bottom end that needs a crank, comes with cylinders aswell, and a complete RZ 350 Power Valve engine that needs rebuilt and some PV components, comes with Wiring Harness. Contact me for prices on those items.
Thanks,
Blake.
RPM billet carrier.
Never used still in the packaging all balls swing arm pivot bearings, seals, sleeve.
Billet prodesign shifter.
SS rear brake line, should work with up to a +3 or 4 swinger, works with shorter lengths just has a little slack.
New in box banshee clutch hub.
Banshee Spindle/hub/calipers.
YFZ Spindle/hub/calipers + Lever/MC
YFZ Motion Pro twist throttle+Cable.
Banshee bottom end
Has a chip in the case from the chain coming off, cases still in tact
3 Pairs of yfz rear hubs + stock rolled lip rims.
YFZ front suspension.
Durablur +2+4 yfz axle
  • 2 weeks later...
It's all in great shape. I responded by email and PM volfan. I've been having trouble with bansheehq's site recently. Email me back as soon as you can.
