225GUY Posted August 3, 2009 Report Posted August 3, 2009 If i removed my T-5's and went with CPI in frame small bore pipes and also changed my stocker carbs out to Keihin 35 PWK'S....would it make a big difference? Quote
RZBansheeMan Posted August 3, 2009 Report Posted August 3, 2009 If you already have them or could get them cheap enough, try 'em. Quote
shawn941 Posted August 3, 2009 Report Posted August 3, 2009 If i removed my T-5's and went with CPI in frame small bore pipes and also changed my stocker carbs out to Keihin 35 PWK'S....would it make a big difference? with your mods you are restricting that motor big time running them stock carbs,,,,35's would be a good choice if u ever plan on a 4mill,,,othedrwise 33's would be great also Quote
225GUY Posted August 3, 2009 Author Report Posted August 3, 2009 So the cpi's and 35's should make a good bit of difference? Quote
shawn941 Posted August 3, 2009 Report Posted August 3, 2009 So the cpi's and 35's should make a good bit of difference? wshat kind of port work do u have done? Quote
225GUY Posted August 3, 2009 Author Report Posted August 3, 2009 full drag port with boost port holes also Quote
shawn941 Posted August 3, 2009 Report Posted August 3, 2009 full drag port with boost port holes also lol,,,u will love it man. also,if u dont already have a pingle valve,,,with 35's u sould get one,,,,ditch the stock petcock. you will unleash some power withe them carbs and pipes for sure,,,let me know how it works out Quote
