im about to order some uni pods from rmatv, need to know which size fits 33mm pwk's as they only list mikuni sizes..... 2 1/4 or 2 1/2??
ok im guessing the 59 is in mm's correct? if so that converts to 2.32 inches, so a 2 1/2 would work?
If i am not wrong you need a 2 1/4 size filter...http://www.sudco.com/knca.html over here look for YAMAHA ATV and at flange dimension is the size of the filter...
if i go by the dimensions on the keihin website the 34mm pj and the 33mm pwk have the same flange dia, what size is on yours????
yeap, on 33, 34 and 35 is the same size and mine are 2 1/4...and sorry the link is this Sudco
Edited by gst_r
Man i appreciate it, thanks alot!
Just a heads up... There are "fitment issues" with 33pwk's and the t-5's in your sig. Those RU-0620 filters wont work with a one peice Boss intake for instance... Maybe save you from buying two sets of filters like I did??? :down:
quick question and not on the carbs wanted to know where you got your lights and plastics
