To me what I'm hearing is you flooded it out. When its flooded the excees goes down in the cases if it was flooded a few times,prevoius owner & you with the bad cdi, the gas will eveporate but the oil wont you might just need to get on her wide open blow it out, check the plugs cause theyll probably need replacing after clearing all the oil out. If your being caustious & havent tried that yet I'd probably start there. Then play with the jetting.
Could there be a spark issue?
shouldn't be spark if it will run, i'd put it back to stock settings and work from there with exception of your mains. you should be able to get it dailed in good, 3 turns seems like a bit much on the air mix screws.
