randytbo Posted June 16, 2009 Report Posted June 16, 2009 i baught yamalube for mine. i havnt put it in yet though. do u guys recommend it or would it be a better fire starter??? Quote
jbooker82 Posted June 16, 2009 Report Posted June 16, 2009 yamaha lube will work fine. It is just an engine oil that is wet clutch compatable. Oils that are made for 2 stroke transmissions shift smoother. Quote
stroking Posted June 16, 2009 Report Posted June 16, 2009 what is ATF ? anyone have a pic of it.....where can i get some ? Quote
jbooker82 Posted June 16, 2009 Report Posted June 16, 2009 Automatic Transmission Fluid. There are several types of fluid. Type F is what everybody is running. Quote
GrMeyer Posted June 16, 2009 Report Posted June 16, 2009 (edited) You can get it at any auto store...I try to get mine from Walmart. They always seem to have the best prices for any oils. I want to buy a 5qt motor oil form truck and auto zone wanted like $5 more then walmart. But sense I run Type F in my trans I just buy the cheap shit because I change it so often Edited June 16, 2009 by GrMeyer Quote
slopoke Posted June 17, 2009 Report Posted June 17, 2009 Same here. I use it because of the low viscosity. It really made a huge difference shifting. I used to use Motul. I just did a complete rebuild, and my transmission looked like brand new. I change the fluid about every 10-12 hours. Whatever you use, make sure it's made for wet clutches. Motor oil is not made for wet clutches. Mobile one's regular oil that you can buy at the local wal mart has the additive for wet clutches. It meets every requirement of the factory specs. I have recently started using atf dextron II and have had really good luck. Type f works well also, but like they mention you need to change it more often. But if you want to run something other that atf with a little more run time before changes and easily found at parts houses and walmart go with mobile 1. You pick the weight, Quote
potpye Posted June 17, 2009 Report Posted June 17, 2009 B&M Trick Shift is what I use it works great, it is a form of type F ATF we have been using it for years it is cleaner and is wet clutch compatible. Regular oil is not wet clutch specific. Quote
