canes454 Posted May 13, 2009 Report Posted May 13, 2009 how would i eliminate my tors with out buyin a eliminator kit, if possible at all still want her to idle and be able to rev up right and answers would help, the more specific the better Quote
shee4speed Posted May 13, 2009 Report Posted May 13, 2009 why dont you just buy the kit.I think people want them gone so those big huge boxes are gone from the tops of the carbs.Also the electronics FUCK shit up,. Specific enough? Quote
BellicoseBanshee Posted May 13, 2009 Report Posted May 13, 2009 Disconnect the control unit, the carb switches, and the throttle switch (the parking brake switch is wired to the CDI) and that will effectively remove the TORS. As mentioned, the TORS kit is needed when the carb switch blocks are removed... Quote
AKheathen Posted May 13, 2009 Report Posted May 13, 2009 maybey your question should be a little more specific. you just want the electronics gone? listen to bellicose. everything will run exactly the same as before, but without killing spark. i would get the kit to remove the cumbersome boxes. it will save you hours over the years, and doesn't cost more than the cost of new rubber intakes that you'll save from cracking by relieving the stress. btw. the tors controll box is located under the gas tank-left side. here's a diagram to help Quote
