Hey do any of you use any type of sealer on the outside of the crank seals?
If so what do you use(yamabond,RTV,ect...................)
Thanks,
Bill
Thanks,
Bill
I've changed crank seals twice, once in an old engine when they failed & in a brand new engine after having the crank welded & did not use any sealant on the seal itself & have never had any problems with those installations. I do however put a film of grease on the inside of the seal where the crank protrudes through.
Yea that's what I was thinking, the last thing I want is to put the case halves together and have a fuckin leak around the seals.
