2strokecook Posted May 4, 2009 Report Posted May 4, 2009 We put the motor back together friday and here is a list of things i have done to the motor, k&n filter, 30mm carbs, prodesign intakes with out cross over tube, ported, cool head with 21cc domes, new pistons, bore, seals in lower end, + 4 on timing, and new stator and flywheel. We did the break in and all, now while riding it around just trying to put some more break in time on it it bogs extremely, and does not want to wind up into the power band. When i get out on the road and if it does ever get into the power band the right side seems to not fire but when i let off the gas a little bit it does fire. It is smoking like a frieght train so i am guessing the jetting is pretty rich, i can't rememeber what jets i have in it. I have switched plug wires, closely monitored the water level and tranny fluid levels to make sure that i am not burning any oil or anti freese and did a compression check and both cylinders read dead on same, plug change really didn't help either. I couldn't go buy jets since stealership wasn't open today so figured i would check for other problems. think this is jut a chase of being way to rich? Quote
shee4speed Posted May 4, 2009 Report Posted May 4, 2009 whats your current jetting and elevation? Quote
2strokecook Posted May 4, 2009 Author Report Posted May 4, 2009 (edited) whats your current jetting and elevation? i can't remeber what my jets are, i goin to pull them out in the morning and see what i can do with them my elevation is about 660, have any clue where i should start with the jetting? Can my problem with the fire be from it gettin flooded out or no? thanks Edited May 4, 2009 by 2strokecook Quote
2strokecook Posted May 4, 2009 Author Report Posted May 4, 2009 ok nevermind jetted it this morning, runs like a raped ape. Quote
2strokecook Posted May 5, 2009 Author Report Posted May 5, 2009 what did you end up running for jets? right now i have some 142's in there with needle chip at top position, i goona put some 140 in there with the clip in the middle and probable call it good, what you think? Quote
