When I ride on the street I notice it pulls to the left and if I give it throttle it almost throws me off I've noticed a little on dirt and sand but it makes hard to ride on the street
bad shock,tyrods bent,tire preasure,bad bearings on swinger,lots of options..
Tire pressure is the same it feels like its coming from the rear when I lift the front tires off the ground it pulls harder
I refilled the rear tires to 10psi and it helped not pulling as bad I've noticed this with my dirt tires and paddles how do I check the alignment on the rear and front its been pulling since I got it three years ago I always figured quads just did that I grew up on two wheels
theres a link to the service manual at the top of this forum it might be in there so check that out, or theres to bolts under the carrier those should be out the same(count the threads)
