Hi guys I need some help. I am running fmf fatty's with power core 2's it was recently bored 0.30 over from what I was told has boysen rad valves with pro reeds and boost bottle. I am running a K+N air filter wit lid no snorkel and holes drilled in it. The jetting is 280 main stock pilot with the needle on the middle clip.It is smoking white smoke both cylinders and bogging the plugs are getting oil on them too
what is ur fuel mix
ill try dropping the needle it should be on the 2nd clip. im running 330 on the 2nd clip and 50:1 mix. im 60mm over on the pistons. so drop the needle and see if that helps. o ya how many turns is u fuel srew?
The fuel screw is 1.5 out
