the 01 shee (i said it and what?!) i bought has a little roller on top of the chain above the front sprocket, along with the one that bolts in where the swingarm is. did they all come with this? havent noticed it on any others before. is it important?
i have something similar, its a metal piece that bolts on where the swingarm does and has two idler sprockets. are we talking about the same thing? if so idk where to get another one, i heard it referred to as a pro-link once.
is this what your talking about?
i would need a pic since im not familiar with banshees that much, but usually yes, they keep the chain up so it doesnt rub on the swingarm or whatever.
That is not a stock piece on that bike. Look at the aluminum bracket secured with the swinger pivot bolt. Taht is somekind of aftermarket unit I have heard of something called an amplink, is that it??
yeah thats an amplink..
its just got a place where the chain rolls on top and on bottom like a tensioner pully...so when you lay on the throttle on lets say pavement?
you dont get the chain jerk from a lose chain..
yeah thats an amplink i have one. i dont have to worry about that stupid slider on the swinger.
there should be two rollers stock, one on top and one on bottom.. i dont think i run the top one anymore, but probably should. it helps to keep your chain tight when the rear shock is compressed, like when landing off a jump.
I have a question I just got new rollers cause mine were gone who knows where. I just got both and one is bigger than the other does anyone know if the bigger one goes on top or on bottom?
