Running Engine $1000.00
Rubber intake boots/Boost $30.00
Reeds and cages $25.00
Carbs and cable $100.00
Airbox (or air filter) $50.00
Kickstarter $50.00
Gas Tank $30.00
Pipes $35.00 stock - $300.00 chrome aftermarket
Frame components
J Frame $100.00 (title add $100), A-arm frame, $250 (title add $100),
Steering stem $25.00
A-arms / J-arms with brakes, hubs, spindles, and tie rods $300.00
Swingarm $30.00
Axle $100.00
Bearing carrier $40.00
Footpegs $10.00
Nerf Bars / Metal Heel guards $40.00, add $40 for plastic heel guard pieces
Rear Hubs $40.00
Rear Sprocket & Hub $15.00
Rear Brake disc & Hub $15.00
Dogbone $15.00
Rear Grab Bar $10.00
Front Bumper Pushbar $20.00
Shifter $10.00
Skid Plate $20
Plastic
Front & rear Fenders $100 - $200.00
Radiator Plastic $35.00
Gas Tank Plastic $35.00
Seat w/ latch $30-$75.00
Fender brackets $15.00
Electrical
CDI Box $60.00
Wiring harness / Loom $30.00
Coil $30.00
Headlights $75.00
on/off switch $25.00
Key w/ plastic housing $30.00
Taillight $20.00
Misc
Rear brake setup $100.00
Bolt set $25.00
Rear Shock $75.00
Front shocks $70.00
Front tires & rims $100.00 varies
Rear tires and rims $100.00 varies
Handlebars & grips $10.00
Clutch lever / perch $10.00
Thumb Throttle assembly $25.00
Radiator & Reservoir $30.00
Radiator and lines - $20
Front brake lines $10.00
Front brake lever/rezzy $15.00
Motor Mounts $10.00
motor parts:
cylinders $300
crank $170
shift drum, rods, forks $25
gears/tranny $130
cases $150-$200
clutch cover $30
stator cover $ 10
stator + timing plate $80-$100
internal bolts $25
head $20
flywheel $75-$90
  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
how much for the 3rd set down on the far left look kinda like shorter paddles? and the 2nd set from the top on the far left are those mud sharks? lmk def wanting some smaller tires for fun.
the first row are REALTOR tires (flip one way for mud, other way for sand) - $150 on alum rims
those other paddles are sold
I do have a set of 10 paddle haulers on diuglas rims on ebay right now
see my signature for auctions
How much do you sell flywheels for? Also cdi?
flywheels - $80 great shape, $90 mint shape
shiping $12.75
cdi box - $60
shiping 10.75
This topic is now closed to further replies.
