trailrider Posted March 3, 2009 Report Posted March 3, 2009 does any body now what size base gasket i should go with a 4mil crank and cheetah club for deck clearance and does it matter which way does the crank seal goes, i think i put it in backwards Quote
trailrider Posted March 3, 2009 Author Report Posted March 3, 2009 does any body now what size base gasket i should go with a 4mil crank and cheetah club for deck clearance and does it matter which way does the crank seal goes, i think i put it in backwards guess not Quote
moneybags Posted March 3, 2009 Report Posted March 3, 2009 CP web site calles for a .012 base gasket. Quote
XxMeltIcexX Posted March 3, 2009 Report Posted March 3, 2009 The crank seal on the clutch side matters, the crowns should be pointed towards the crank for spacing reasons.. The stator side not so much, I always put the smooth side towards the crank and the writing out. Eric Quote
trailrider Posted March 3, 2009 Author Report Posted March 3, 2009 The crank seal on the clutch side matters, the crowns should be pointed towards the crank for spacing reasons.. The stator side not so much, I always put the smooth side towards the crank and the writing out. Eric thanks moneybag and ice good looking out Quote
locogato11283 Posted March 3, 2009 Report Posted March 3, 2009 welcome to the HQ.. you joined on my birthday which gives you extra special bonus points. :beer: Quote
trailrider Posted March 5, 2009 Author Report Posted March 5, 2009 welcome to the HQ.. you joined on my birthday which gives you extra special bonus points. :beer: i know this is a stupid queston, but what side is the crown of the seal Quote
okbeast Posted March 5, 2009 Report Posted March 5, 2009 I always put the metal springy thing of the seal to the inside. I believe that makes it where the writing is out. I think that's right but no promises. Fuck, that may be bassackwards though Quote
trailrider Posted March 6, 2009 Author Report Posted March 6, 2009 I always put the metal springy thing of the seal to the inside. I believe that makes it where the writing is out. I think that's right but no promises. Fuck, that may be bassackwards though its has springs on both sides, but one side has hmps or nuchers on the oter rubber on one side Quote
XxMeltIcexX Posted March 6, 2009 Report Posted March 6, 2009 its has springs on both sides, but one side has hmps or nuchers on the oter rubber on one side No one wants to talk about seals for some reason lol, damn man you still don't have this thing together!? The Crowns (little nubs I guess) point in, for spacing reasons. Other side has springs in BOTH sides. Put the smooth side in. Quote
trailrider Posted March 6, 2009 Author Report Posted March 6, 2009 No one wants to talk about seals for some reason lol, damn man you still don't have this thing together!? The Crowns (little nubs I guess) point in, for spacing reasons. Other side has springs in BOTH sides. Put the smooth side in. thanks meltice, i had already figure it out myself by searching, thanks for people like you, damn i paid a membership and still no one cares about my stupid question, but i still love this site because it's the best Quote
trailrider Posted March 6, 2009 Author Report Posted March 6, 2009 thanks meltice, i had already figure it out myself by searching, thanks for people like you, damn i paid a membership and still no one cares about my stupid question, but i still love this site because it's the best I had a new queston, but afraid to ask now, I said early i had a cheetah cub with 4 mil crank and a modquad head with 22 domes (4mil) does it change the base gasket size or will i be better off still doing a squish test, I not dumb about doin this, but trying to learn whats new, what i don't know, any help please, i will not forget Quote
okbeast Posted March 6, 2009 Report Posted March 6, 2009 What size base gasket did you use? A squish test is always good just to make sure everything is in proper working order. Quote
trailrider Posted March 6, 2009 Author Report Posted March 6, 2009 What size base gasket did you use? A squish test is always good just to make sure everything is in proper working order. .012 but i think it might to thin with 22 mil (big bore domes) I am new to domes and stroker setup, any help will be a start. tank yo Quote
okbeast Posted March 6, 2009 Report Posted March 6, 2009 .012 is usually one of the more common thicknesses ran. As for the cubs and "cut" domes, if you have a true 4mm cub cylinder they don't require a cut dome. The cylinder is made taller from the factory so it is not needed. Where did you get the dome from that you are wanting to run? I believe a fair squish is anywhere from .040 to .050, you can maybe go a little lower than that but I don't like to risk it. Quote
