trailrider Posted March 6, 2009 Author Report Posted March 6, 2009 .012 is usually one of the more common thicknesses ran. As for the cubs and "cut" domes, if you have a true 4mm cub cylinder they don't require a cut dome. The cylinder is made taller from the factory so it is not needed. Where did you get the dome from that you are wanting to run? I believe a fair squish is anywhere from .040 to .050, you can maybe go a little lower than that but I don't like to risk it. i got the crank, cub, and domes from vito's performance, thanks okbeast Quote
2strokespirit Posted March 8, 2009 Report Posted March 8, 2009 On some seals there is a little arrow, it should point in the direction the crank rotates... Quote
XxMeltIcexX Posted March 8, 2009 Report Posted March 8, 2009 On some seals there is a little arrow, it should point in the direction the crank rotates... What kinda seals you been usin? Quote
