Why is this? Is it a bad thing? Here are specs on my bike its a 98' ,406 big bore with 4 mil stroker crank,vito crank,forged power pistons,boyessen reeds,cool head with 20cc domes ,barnett clutch,toomey T5s,jet kit,pro design filter.
Are you talking about at idle? If so, then I would look for a pilot jet that is clogged. The easiest way to check the carbs is to switch them; put the left carb on the right and vice versa. Now see if the other side smokes more. If so, then you know you have a carb problem.
Good luck and let us know if this works.
Mailman
Mailman
i swaped the carbs to see if it was the carbs its not. also i just put brand new sliencers on not too long ago so its deff not that. do u think it could be the piston
The same thing happened to me not long after I bought mine. I ran a compression test on it. The right side was on but the left side was way off. I had to replace the pistons. After that....good as new...
A compression test is easy and a good idea. Which side smokes more? If it is the right side then the crank seal could be leaking trans oil into the cylinder. I would do the comp. test first.
Good luck.
Mailman
thanks for the help everybody.. im going to do a compersion test today i let you's know it turns out. also how is the seal leak test done?also what type of comperison em i looking for with 20cc domes
Edited by stayblazin
what's your elevation? i would try some fresh gas/premix to rule out separation if your compression checks out within 5 psi of eachother
are you running an aftermarket head or a stock one? one thing I have noticed with the aftermarket head as im sure many people have is if you pinch an Oring it will leak coolant into that cylinder and the coolant will make a white smoke have you pulled the coolant cap off? if not pull it off and see if there is presure in the radiator when you rev it up cold or hot but dont pull the cap off when it is HOTT! check it out let us know
