i highly doubt they will have a nut of that size and thread. its a specialty metric nut as far as i know. only place that would have something even remotely close would be a specialized fastener store.. even then, its not likely.
I didn't think he wanted the nut. I think he is after a socket to remove the nut. I could be wrong though.
SP
SP
haha, yea that is probably what he wanted.. but he didnt say anything about a socket for it. i just assumed he needed the nut. ha.
hahahah. yeah i forgot to mention that i needed the socket size. Sorry but smuttdowg said its 1 1/4 so thats what im getting thankx guys. and sorry for the misunderstanding.
edit.. just as i replied some one said 32mm. and just thinking thats the right size because shees use the metric system wright?
Edited by banshee_terror_
Yep.....
i got the right socket but now how do i hold the hub so i can take off the nut?
if you have an impact wrench you can spin it right off pretty easily. if you don't have that or a tool, you can stick a rag in between the gears to lock them up enough to break the nut loose. i wouldn't use anything hard to try to hold the gears, a rag should do the trick. that's how i hold it to tighten it back up again also.
make sure you bend the tab back on the lockwasher that is behind it before trying to loosen it. don't be offended bud, i've seen people struggle to loosen it and they didn't bend the tab off of the nut. it's just a helpful tip.
Edited by MILO
