yammyboy3 Posted February 9, 2009 Report Posted February 9, 2009 ok so i have this little problem i cant get enough power my banshee right now has pro circuit pipes and delta reeds i want more power what can i do ?? Quote
AKheathen Posted February 9, 2009 Report Posted February 9, 2009 ok so i have this little problem i cant get enough power my banshee right now has pro circuit pipes and delta reeds i want more power what can i do ?? +4 timing and a cool head Quote
yammyboy3 Posted February 9, 2009 Author Report Posted February 9, 2009 what size domes for what i have right now if you know and what does a timing advance do can it really give more horsepower Quote
AKheathen Posted February 9, 2009 Report Posted February 9, 2009 what size domes for what i have right now if you know and what does a timing advance do can it really give more horsepower what is your elevation? what fuel are you running? the timing is set back so that you can run the lowest grade fuel, and not detonate, but some of the burn is wasted out of the exhaust. igniting it sooner allows the burn to develope more by the time it's used for the downstroke. on the other hand, if too soon, it can detonate and cause serious damage. the majic number seems to be +4 for most, and is one of the best power per doolar mods. the plate is like 35 bucks, and i've never heard anyone complain. Quote
dajogejr Posted February 9, 2009 Report Posted February 9, 2009 ok so i have this little problem i cant get enough power my banshee right now has pro circuit pipes and delta reeds i want more power what can i do ?? This is a very easy answer, however....it requires one question. How much do you have to spend?? Quote
STINKYDELUXE Posted February 9, 2009 Report Posted February 9, 2009 +4 timing, cool head (or shaved head) and porting. after that it starts costing a lot more money Quote
FASTOYS Posted February 9, 2009 Report Posted February 9, 2009 Need to know your elevation. A cool head, and timing plate will really wake it up. Also may consider gearing it too. Quote
Banshee_Bandit Posted February 9, 2009 Report Posted February 9, 2009 Why u guys always suggest a adjustable timing plate in combination with a cool head ?!? does setting the timing plate to +4 affect the heat within my topend ?!? Just wanna make sure that I don`t blow up my Shee since I changed timing to +4 but haven`t got a coolhead mod really... cheers lads Quote
mark101180 Posted February 9, 2009 Report Posted February 9, 2009 Why u guys always suggest a adjustable timing plate in combination with a cool head ?!? does setting the timing plate to +4 affect the heat within my topend ?!? Just wanna make sure that I don`t blow up my Shee since I changed timing to +4 but haven`t got a coolhead mod really... cheers lads it will run a lil bit hotter but you can increase ur compression with the cool head. timing and compression are cheap ane easy mods to do. and they are good mods to start with b/c ur gunna want them anyways when you get more involved with your engine mods. and these mods are very adjustable and compatible with future mods Quote
mason07shee Posted February 9, 2009 Report Posted February 9, 2009 I just installed my noss cool head with 20cc domes at 1200ft in elevation and installed carbon tech reeds and a timing plate at +5, i am running 93oct and man what a difference! oh i also changed over to shearers from t6's ...... i wish i would have added 1 mod at a time so i could feel the power difference but oh well Quote
dajogejr Posted February 9, 2009 Report Posted February 9, 2009 I just installed my noss cool head with 20cc domes at 1200ft in elevation and installed carbon tech reeds and a timing plate at +5, i am running 93oct and man what a difference! oh i also changed over to shearers from t6's ...... i wish i would have added 1 mod at a time so i could feel the power difference but oh well If you still have your T6, put them on...try them. Quote
SLORYDER Posted February 9, 2009 Report Posted February 9, 2009 P to the o to the r to the t it Quote
yammyboy3 Posted February 9, 2009 Author Report Posted February 9, 2009 well im not to sure of my elevation i live in southern jersey thogh and i run 93 pump fuel and no money wont be an issue as of feb 20th Quote
uwenr Posted February 9, 2009 Report Posted February 9, 2009 well im not to sure of my elevation i live in southern jersey thogh and i run 93 pump fuel and no money wont be an issue as of feb 20th Google it Quote
