Like the title says. What are the most common problems associated w/ high hp banshee motors?
Generally the rods are the first thing to go, right?
Clutch slippage was my biggest problem. Had to add a ton of weight to the locker.
No problems with my trans. (110hp+) 2nd gear is weak.. but I think stock 2nd is good up to 120ish . But I do agree.. The weakest link in a big HP motor (besides the clutch) that isn't caused from user error is the 2nd gear...
x2, im running a stock tranny and its fine, but the clutches are weak, ended up running a lock up
