98_shee Posted December 29, 2008 Report Posted December 29, 2008 Did you put the bowls back on the rite carbs? And is the balance tube in place? Quote
Yamaha4ever Posted December 29, 2008 Author Report Posted December 29, 2008 its got a pretty good flow of fuel on that side... but its almost like its not igniting on that one side , its running but its not blowing out any hot air or smoke Quote
Paddleboy Posted December 29, 2008 Report Posted December 29, 2008 sounds to me like you may have got something in your carb. even after cleaned one piece of dirt can clog it. Quote
locogato11283 Posted December 29, 2008 Report Posted December 29, 2008 clean carb again. make sure theres nothing in the pilot or main jet and spray it all down good with carb cleaner. Quote
bansheefreak Posted December 29, 2008 Report Posted December 29, 2008 check your choke tube,also make sure your getting the slides in the right carbs... you can cross them and they will be backwards... Quote
locogato11283 Posted December 29, 2008 Report Posted December 29, 2008 check your choke tube,also make sure your getting the slides in the right carbs... you can cross them and they will be backwards... good point.. is the bike revving up real high on start up? Quote
kawiking Posted December 29, 2008 Report Posted December 29, 2008 im guessing stock carbs ? check ur choke tube.. and do a compression test Quote
bansheefreak Posted December 29, 2008 Report Posted December 29, 2008 another thing to check is.. when you have it running pull the choke out if it runs better your not getting enough fuel.. Quote
98_banshee_newbie Posted December 29, 2008 Report Posted December 29, 2008 I suggest the same. But if it is blowing cold air on one side then you are not getting combustion on that side. Definitely get a compression check Quote
Yamaha4ever Posted December 30, 2008 Author Report Posted December 30, 2008 yea im gonna take the bike up 2 a local shop and do a compression test and see what they say may be wrong... i agree its not getting any combustion on that one side which doenst sound like a very cheap fix, but i could be wrong it may be something minor, yea they are stock carbs, has a little work done to it, bored out a little, fmf fatty pipes, nice bike when its running right pretty quick i Thanks for all of the help i greatly appreciate it keep it coming lol Quote
