lokisbuddy Posted January 17, 2009 Report Posted January 17, 2009 My blaster was really fast heres what i was running hope it helps. Boysen rad valve k&n air filter w/outer wears and no box lid reed spacer tors removed dpk clutch kit 14/40 gearing maxxis razrs 3 mil stroker hollowed out silencer (couldnt afford a toomy that i wanted lol) rejeted will post vids if youd like Quote
blaster2006 Posted January 17, 2009 Report Posted January 17, 2009 My blaster was really fast heres what i was running hope it helps.Boysen rad valve k&n air filter w/outer wears and no box lid reed spacer tors removed dpk clutch kit 14/40 gearing maxxis razrs 3 mil stroker hollowed out silencer (couldnt afford a toomy that i wanted lol) rejeted will post vids if youd like why do people say" rad valve" its reed valve. For a pipe, the only best top end is LRD, its the number 1 top end pipe for blasters. DO not get FMF pipes for blasters they suck aswell as DG. both those are like stock, i have had a blaster for 2 years and tried countless pipes. i kept my Factory 7 pipe, its the best all around pipe. Toomeys arent bad too. for the blaster, not as good as they are for banshees. get a pod filter and high rejet is the best mod you can do to it other than porting, best bolt on is a pod + rejet, then a pipe., then reed valves. then porting, if your gonna port, go for bigger carb. Quote
lokisbuddy Posted January 17, 2009 Report Posted January 17, 2009 why do people say" rad valve" its reed valve. Actually I am sure you will find you are wrong my friend may I now present exhibit "A" http://www.denniskirk.com/jsp/product_cata...tId=&mmyId= Quote
lokisbuddy Posted January 18, 2009 Report Posted January 18, 2009 (edited) oh yeah you may want to get the shortened brake cable and parking brake blockoff kit if it is not equipped with a hydraulic rear. sorry for the double post Edited January 18, 2009 by lokisbuddy Quote
250Rho Posted January 20, 2009 Report Posted January 20, 2009 if its a 99 your gonna want to modify some warrior or banshee spindlels so you can have decent front brakes cause if you get those drums dirty and wet your gonna die. drums dont work wet or dirty ,disks are the tits :biggrin: Quote
RollinRhino Posted January 20, 2009 Report Posted January 20, 2009 "RAD VALVE" is a Boyesen product. I ran one on my CR 125 back in the day. I believe RAD Valve is also trademarked, but am not sure on that. Quote
