need help building up a 99 blaster. i want to build it for a trail bike with lots of torque. i have never messed with a blaster so i need some help. i have about 1000 to spend so tell me the best mods to build a good torque monster to ride while the shee is down. also any tips or tricks i need to know about the blaster and must have parts for it.
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
Agressive trail port, Toomey pipes, port the stock reed cages and get some carbon petals, wiseco piston, re-jet it, pod filter. Do your research and you can get all that for under a grand use the change to find some after market shocks. Blasters are banshee's little brother so they are pretty simular
ive got a wicked ass blaster with a shit ton of tourqe. i got the vf3 rreds and cage 1/2 reed spacer 300 main k&n with outerwaer and fmf fattie with power core II. and i can pull the front wheels up thru third pretty easy. i also widened it 6 inches. they r great bikes for tight trails but arent shit for top end unless you regear em.. id also recomend getting a shorty brake cable kit to eliminate the parking brake. pm me if you needf some parts or help. ive done mine and my buddies had a few so im there when it comes to them lol. got 3 frames in my basement of my buddies also
when i start building i will probably ask you for alot of help since you have built a few blasters.
that is what i needed to know thanks for the help.
ok, that bike has a pretty predominant torque setup already, but you can start with porting the stock cage, put some boysen prostock pedals on. that stoch pipe will hang out on both the top and bottom end if you change out the stock silencer for something better. you can bolt some yfz suspension parts strait on, i don't remember exactly what, because it's been several years, but i would first concentrate on getting that rear swinger to squat far down as you can when you take off, while keeping it high normally, or you will end up on your ass more than you can use the power in tight spaces (my back is still messed up) put some 22's on the back. set up your handle bars so you can almost kiss the front bumper, because you will need it occasionally. proper jetting is a must. i have rode mine in verry tight trails, up hill climbing, beach racing, high speed dirt road (up hill with switchbacks) if you start going too aggresive with the mods, you will loose alot of low end, and trail abilities, being left with something similar to a stock banshee when it's maxxed out, but you already have a banhee, and that would defeat the purpose. it's a fun little bike that you can really throw around, and will get you out of so many spots, that you'll forget it's 2wd.
one thing i was gonna try out, is installing a 250cc resonator to the intake boot to clean up the low end, but will have to rejet :shrug:
il be happy to help. my buddy thinkgs there a pain but there simple just gotta be patient. just hit me up with any questions
heres a pic of mine so you know what im talkin about.lol
holly geez, i was eating dinner in the middle of my post, an went from post 4-9. anyways, i can't agree on the top end, cus mine would do about 80 with no problem.
id say mine as is with the 13 tooth front and the 40 tooth in the rear with 20s on it prob goes 65ish give or take. a yz80 beat me in a race lmao
tell me more about the yfz parts swap if you can remember or pm me later.
sweet bike and that gearing would be good with 20s but i'll probably run bigger i plan to run small itp mudlites or vampires and will need a little different setup.
oh, yikes, i shift to 6th a little past 65, and gave the bike to my bro when i got beat by a 500 in a short run, and couldn't keep the front wheels down enough (got tired of kissing the front bumper everytime i tried to hillclimb, and landing on my ass every time i climbed up out of a tight spot) tell me you had him by a long shot up till 65 :biggrin:
